Delta Arm Blues?? Or something else??
Posted: Thu Nov 28, 2013 12:07 am
So I've printed 10 of these z-calibration test and there seems to be no improvement. All of them are printed in the center of the glass plate.
Before printing out the next Z-calib i tweeked the filament diameter and extrusion widths to test which would be the best. I thought that at one point Id finally get a perfect print.
I've tried differnt temperatures for the extruder and bed as well.
My question has to do with #9 and #10
I printed out the just the first layer of #9 and it came out perfectly. But when i did the print again without changing anything the infill wasnt correct. And then i tried the same for #10 and had different errors.
Im aware of delta arm blues are but I have the tricklaser arms. I always thought that the D.R.B had to to with the friction of the arms due to improper sanding. Could it be possible that my tricklaser bands are too tight causing too much friction?
Does anyone know why I cant infill correctly? Any advice?
[img]http://i.imgur.com/dkQ7Gq2.jpg[/img]
[img]http://i.imgur.com/Yq4crxw.jpg[/img]
[img]http://i.imgur.com/SlECBXm.jpg[/img]
[img]http://i.imgur.com/K9jj3vO.jpg[/img]
