So a differrent approach to the LED ring.
Posted: Sat Nov 30, 2013 5:44 am
I have not jumped onto the LED ring bandwagon as many of you may know.
The primary reasons being that I really do not like the idea of adding any weight to the effector since I really like to push the speed without loss of quality.
So here is my approach of doing it and it has a few bonus tricks to show for it too. Still working out the kinks, but it is essentially a large clear acrylic ring with a flexible multicolored led ring facing inwards on the outside of it. The effect is that the ring slightly diffuses the ring and also directly focuses the light into the center of the build platform.
The ring is large enough to not be within the print area (not the edges I use anyways.
No added weight on the effector at all.
No effect on build height at all either.
Gonna try to hack the light changing feature to show red while bed is heating and blue when cold. Greenn when ready to print and white when printing.
Here are some pics.
The different led colors are accessible through seperate traces on the flexible package that they are mounted too. So it's really a matter of simply feeding the 12v signal to the color of led you wish to illuminate. Which is easily taken from the feeds of the controller board.
Here are some pics.
