Page 1 of 2
Upgrade or throw away?
Posted: Sun Dec 01, 2013 10:34 pm
by untitled86
I purchased a year ago and never really got my printer working properly. I could print calibration objects sometimes, but it seemed like things constantly needed to be adjusted. Most of my actual prints failed.
I had started with ABS, more recently I acquired some PLA and that seemed like it worked much better. ...But now I keep overheating and clogging the filament in the filament sheath near the top of the hotend. My printer is stock, the only upgrade I purchased was the glass Oynx bed.
Anyways, I need a working 3D printer. I'm at the point where I'm ready to buy a makerbot or something pre-assembled. Should I just do that?
I bought my printer over a year ago, I figure a lot of things have changed. By now the community here should know what works best where. So, what upgrades should I buy to bring my Rostock Max up to speed, or should I just give up on it?
Re: Upgrade or throw away?
Posted: Sun Dec 01, 2013 10:54 pm
by cope413
I think you should give up on it and sell it to me for $500
Posted: Sun Dec 01, 2013 11:08 pm
by Nylocke
I think someone is desperate for a printer.... If I were you, I'd get an E3D and slap it on there, they work great, never had any problems with the one I installed on my works MAX or the 3mm one on my Ultimaker. Its is the only hot end I truly recommend to anyone. Greatest thing about it is its all metal, so no parts to melt and you can print with any material, so no replacement plastic bits to buy if they fail and no extra money to spend on upgrades or a new all metal hot end when you decide to try polycarb or nylon
Posted: Sun Dec 01, 2013 11:11 pm
by CJGerard
Your gonna have problems with what ever 3d printer you buy unless you spend an insane amount of money on it. The guys at SeeMeCNC are good about helping out and the guys on the forum here are just flat out awesome!!! Since this is a new technology there are going to be road bumps and setbacks. I purchased my rostock because:
1- I didn't have an insane amount of money to throw around
2- Because of the crazy amount of help and support from the community.
3- The deal clincher was touring SeeMeCNC facility, I met Partdaddy and he showed me around. Everyone there could be making a ton of money doing something else, but they are passionate about what they do and what they make. The reason you max is now outdated is because they constantly look for flaws and ways to improve their design, then incorporate them into the product as fast as they can while making it so the older versions can be upgraded as well.
This is the type of company that i like to buy stuff from. Take a look around and see how many RS-Max's are for sale compared to other printers, then look at the price. In many cases they are more expensive or the same price as buying a new one. For a small company in Indiana, this speaks volumes. At the end though its still up to you to make your final decision.
Personally, my choices would come down to either keeping the max and fixing it, or selling it and buying an Orion.
Posted: Sun Dec 01, 2013 11:50 pm
by Toyguy
I have very little experience but my freshly built MAX is working quite well. It still needs some tuning, and I still need to do some learning, but I really cannot complain. A business near me that does contract 3D printing has 2 MAXex, an Orion and a Makerbot. They hate the Makerbot, claiming it has been out of service more often than not. That's hearsay, but they make their living doing 3D prints and they generally print on the Rostocks.
I did quite a lot of investigation before buying my MAX, and I just couldn't see what Makerbot brought to the table for the money they charge. Given the maturity of their technology, there's no reason that machine shouldn't sell for much less.
If it were me, I'd work on the MAX. Make sure you get the new extruder and delta arms, or get the Trick Laser arms to avoid that potential issue. Maybe pick up a new hot end with the new nozzle design, or at least the new nozzle. Make sure you have a PEEK fan and get a layer fan set up. Repeat the key parts of the setup - square the towers to the base and the top plates. Use Gene's manual to tune and set Printer Radius and Z height. Make sure your firmware and Repetier Host are up to date. Then try some calibration objects and post here for help adjusting it.
Posted: Mon Dec 02, 2013 12:56 am
by untitled86
So, I should buy this set of arms?
http://tricklaser.com/Carbon-Fiber-Tube ... M-CFTX.htm
My arms, and the joints, worried me before. Once, 8 hours into a print, the pin holding one of the arms in place slid out of place causing chaos.
What about that E3D hot end? Is that the best hotend for these printers? Who should I buy it from? If anyone knows what hotend and fan setup work best, please post a link to the product so I can buy it. I didn't see a fan kit on the seemecnc site.
Posted: Mon Dec 02, 2013 1:26 am
by Toyguy
Yep, that's the arms I have and they are rock-solid. They come with a set of rubber anti-lash straps and they require no sanding or filing.
I don't have an E3D, but I will soon. There's now a US distributor for them and I believe they come complete with a fan and mount. They have a post here on the forum somewhere.
Posted: Mon Dec 02, 2013 1:37 am
by CJGerard
I will be getting my new E3D hotend first. Then maybe upgrading my arms, I'm a toolmaker by trade so i kinda had the advantage while sanding my arms to fit and i'm kinda happy with them right now. I can see where a lot of people that don't physically make stuff for a living can go wrong on the arms though. The trick laser arms or the new seemecnc arms would probably help out quite a bit.
IF you have any questions, don't hesitate to ask the members of the forum. They have helped me out alot.
Posted: Mon Dec 02, 2013 1:42 am
by untitled86
Is this what I need?
http://e3d-online.com/E3D-HotEnds/E3D-V ... tal-HotEnd
Are there any other parts I'll need to attach this to my rostock max?
Posted: Mon Dec 02, 2013 1:44 am
by untitled86
CJGerard wrote:The trick laser arms or the new seemecnc arms
Those new seemecnc arms are much less expensive. Are they really comparable, performance wise?
Posted: Mon Dec 02, 2013 1:58 am
by CJGerard
http://forum.seemecnc.com/viewtopic.php?f=38&t=2808
Check this thread out in the forums for the hotend. There is a US supplier for it.
Also here is a revew of the new seemecnc arms on youtube.
http://www.youtube.com/watch?v=f_Lb_igsG1g
As i said, i still have my stock arms but i have heard good things about both the new seemecnc arms and the trick laser arms.
Posted: Mon Dec 02, 2013 8:24 am
Depending on when you bought your kit, you may or may not have the EZStruder. I've got to sing its praises, if you've got Steve's gear reduction extruder you should upgrade.
I was having a lot of trouble on my Rostock, and I upgraded to the EZStruder and a hotends.com JHead and I wish I'd done both sooner. I also have the carbon fiber trick laser arms, that's a must do as well. Brian makes great parts. They sell an LED ring and other accessories too.
Also, make sure you're using Repetier firmware instead of Marlin and all that good stuff too.
Posted: Mon Dec 02, 2013 9:25 am
You don't need a new hot end. You DO need a fan on the PEEK section to prevent PLA from jamming.
The pin holding the arms fell out because you didn't tighten the screws properly. They don't magically back out.
The new-style injection molded arms work great! I've got three machines that use them and zero "DAB" problems.
Posted: Mon Dec 02, 2013 11:03 am
by Nylocke
If you get an E3D get a bowden 1.75 version, it'll save you some annoyances. Dunno what your talking about Jim, I use Marlin on all of my printers, including the MAX I built
Posted: Mon Dec 02, 2013 12:07 pm
by cope413
Guys, c'mon, you're all just giving him a lot of work. I already generously offered $500 for his machine. I'll up it to $505 to cover the time he needed to read all of your supposed "help".
Posted: Mon Dec 02, 2013 12:19 pm
cope413 wrote:Guys, c'mon, you're all just giving him a lot of work. I already generously offered $500 for his machine. I'll up it to $505 to cover the time he needed to read all of your supposed "help".
You're too generous. Offer him $503 and use the other $2 to buy some more capacitors.
Posted: Mon Dec 02, 2013 6:49 pm
by Nylocke
I would offer him at least $700, for all the time and effort he put into it. Its $1000+ for the whole kit, and he's already assembled it mostly, watchu doin cope 0.o
Posted: Mon Dec 02, 2013 7:03 pm
by untitled86
The $500 seems fair to me. But after I spend $$$ on these upgrades, I'll probably want something like $700 + shipping. ...IF I can't get it to work.
So far I'm hearing....
1) Trick Laser Arms - More expensive, maybe overkill, worth the peace of mind.
2) New hotend with fan on PEEK section. I'm thinking E3D Bowden...
http://www.filastruder.com/products/all ... e3d-hotend
3) EZStruder? I hate the extruder on my Rostock Max. ...Even though it seems like it's been working flawlessly. What parts do I need to buy to upgrade this? Is this the kit? ...
http://seemecnc.com/collections/parts-a ... ld-end-kit
Thanks again for all your help.
Posted: Mon Dec 02, 2013 7:13 pm
by CJGerard
The E3D doesn't have a peek section, its all metal and can go to higher temps.
I Have the EZStruder on my RS-Max, it seems like it is alot less complicated than the old extruder and more reliable. It also moves the filiment to the top instead of the side so the machine itself takes up less space.
Sounds like your gonna keep your max. I hope everything works out for you.
Posted: Tue Dec 03, 2013 8:44 am
Nylocke wrote:Dunno what your talking about Jim, I use Marlin on all of my printers, including the MAX I built
Marlin works very well, there's not a problem with it or anything like that. Repetier is just "smarter" in how it calculates tool movements (especially speed) plus it's the currently supported firmware that's getting updates and bug fixes that are specific to the Rostock. That's why I advise using it. If it's not broke, don't fix it
but if you're already frustrated with your machine it might be a fresh step in the right direction. (no kitty litter pun intended)
Posted: Tue Dec 03, 2013 7:28 pm
by untitled86
The fact that I didn't know what the peek section was gives you a glimpse into how much I don't know. Thanks for the help, I need it.
Posted: Tue Dec 03, 2013 7:42 pm
by untitled86
Jimustanguitar wrote:Nylocke wrote:Dunno what your talking about Jim, I use Marlin on all of my printers, including the MAX I built
I've been using the Marlin firmware. I'll also try switching to Repetier. So to re-cap, I will...
1) Buy this new hotend with fan on mid section which should prevent the PLC from jamming...
2) Buy the Trick Laser arms...
3) Buy the EZStruder...
4) Switch to the Repetier firmware.
Anything else?
Posted: Tue Dec 03, 2013 8:11 pm
If you are going to use PLA you will need a cooling fan.
You will need a mount for the E3D Hotend, I recommend you purchase the bowden version of the E3D
and use this as the mount:
http://www.thingiverse.com/thing:137140
Posted: Tue Dec 03, 2013 11:00 pm
by Nylocke
A cooling fan for PLA isn't an absolute must, Ive gotten away without one platy of times, including some times i probably shouldn't have, though it helps a lot to have one
Posted: Wed Dec 04, 2013 9:17 am
...or you could just install a PEEK fan on your stock hot end and use that...
You CAN print for _short_ periods of time without a fan, but you're better off with one.
