Question about ABS hygroscopy
Posted: Mon Dec 02, 2013 6:09 pm
by dpmacri
I've been doing things recently to try to keep my ABS filament dry since I started to get some lousy prints after a spool of SeeMeCNC neon green had sat out for about a month. I noticed that it visibly looked different and the print quality was getting pretty poor. Switching to a new spool eliminated the print problems. So I went about working on drying out that filament and looking into ways to keep new filament dry.
In the process I started thinking about ABS and the fact that Legos are made out of ABS. And I began to wonder why Legos don't end up with the discoloration problem like I saw or, in general, any kind of change in their characteristics over time (old legos snap together fine with new ones). Certainly, my kids aren't putting their Legos away in low relative-humidity containers :-D
Maybe there's a simple explanation, but I'm curious if anyone actually knows the answer.
Re: Question about ABS hygroscopy
Posted: Mon Dec 02, 2013 6:41 pm
dpmacri wrote:I've been doing things recently to try to keep my ABS filament dry since I started to get some lousy prints after a spool of SeeMeCNC neon green had sat out for about a month. I noticed that it visibly looked different and the print quality was getting pretty poor. Switching to a new spool eliminated the print problems. So I went about working on drying out that filament and looking into ways to keep new filament dry.
I'm not sure but I would imagine that Legos have an additive that prevents them from being able to absorb moisture.
Posted: Mon Dec 02, 2013 6:43 pm
by dpmacri
If that's true, then I'd be curious to know if anyone has ground up Legos in a Filabot or similar extruder and whether or not the resulting filament is no longer hygroscopic.
Posted: Mon Dec 02, 2013 7:19 pm
I don't know about grinding up Legos but if the manufacturers wanted to do so, they could create filaments that not hygroscopic. Let's hope that is what the future holds for those of us who use their filaments.
Posted: Mon Dec 02, 2013 7:58 pm
by cope413
Legos absorb moisture, but you don't notice because ABS only absorbs a relatively small amount by volume.
However, when you're extruding it, that small amount of moisture can make a huge difference because the tiny drops of water vaporize in the hot end and cause air bubbles, and changes in extrusion temperature which negatively affect print quality.
ABS is hygroscopic, but is not chemically altered by the presence of moisture while extruding - unlike Nylon and PC - which actually hydrolyze and get weaker.
We will actually begin selling drying boxes very soon (maybe as soon as later this week) in order to protect your filament and maintain high print quality, and we'll have a full write-up/explanation about the effects of moisture on filament and printing.
Posted: Mon Dec 02, 2013 11:11 pm
by dpmacri
cope413 wrote:Legos absorb moisture, but you don't notice because ABS only absorbs a relatively small amount by volume.
Thanks for the explanation! Depending on the price, I'll likely be buying one of your boxes when they're available :-D
Posted: Tue Dec 03, 2013 1:50 am
by CJGerard
dpmacri wrote: Depending on the price, I'll likely be buying one of your boxes when they're available :-D
hehehe ;)
Posted: Tue Dec 03, 2013 9:07 am
by Jimustanguitar
I appreciate that explanation as well. I'd heard others say that ABS couldn't be affected by moisture because it wasn't water soluble like PLA so it couldn't absorb it... You used bigger words, so I believe you :)
Posted: Thu Dec 05, 2013 2:49 pm
by Durandal
If anyone could figure out a way to move the moisture from filament to a cigar humidor, without stinking up the sticks, I'd pay top dollar for that. :D
Posted: Thu Dec 05, 2013 4:13 pm
by cope413
Jimustanguitar wrote:I appreciate that explanation as well. I'd heard others say that ABS couldn't be affected by moisture because it wasn't water soluble like PLA so it couldn't absorb it... You used bigger words, so I believe you :)
Yeah, that's definitely not accurate information on multiple levels. First, PLA isn't water soluble. Second, hygroscopy has nothing to do with water-solubility. Third, PLA used in 3D printing is actually MORE hygroscopic than ABS in the amount of moisture it can absorb by weight.
