1. Using PLA for now, is filament oozing from the nozzle on its own of any concern? I was wondering if it meant my temperature was too high. I'm using 185C but my thermocouple isn't here yet so I can't guarantee how accurate that is.
2. Is there any well to tell what, if anything, Slic3r is doing? It's been slicing a fairly small, though possibly complex, object for well over 90 minutes.
3. I wanted to print a small bracelet that, when loaded into Repetier Host, came in on its side. That didn't seem a very good way to print it, so I used the functions in Repetier to lay it over and reposition it on the surface. It looked fine in the object view. I sliced it without issue, and the slicer paths all looked good, with the bracelet flat. When I went to print it, however, it began trying to print it as if it were still on its side. Anything else I need to do to change the orientation of an object? I have successfully been able to place multiple objects and move them around the build surface but this was my first attempt at re-orienting an object.
4. If I want to try out other slicers, is it as simple as using the slicer outside of Repetier to save a GCode file, then just load that GCode file into Repetier and RUN JOB?
Dave
