Not printing flat
Posted: Thu Dec 05, 2013 7:43 pm
So, If I calibrate the towers and radius so that each of the 4 locations is spot on. It still draws an arc. As I tried printing a larger object, anytime it got close to a tower it would dip into the surface and then immediately raise as it travels away. It's very consistent at this, If I try to run a large circle as a test, it is closer to the bed as it gets closer to the tower, and raises in between. Ideas??
I have a stock Rostock Max, just updated the Slic3r, and running latest rep.
