"Blobbing"?
int2str
"Blobbing"?
Post by int2str »
Got new ABS today and tried it out immediately after my last failure.
The test print came out really nice. The print feels good in hand and looks great.
That said, there is some random "blobbing" happening?
Not sure this is blobbing, but I'm referring to the random "blobs" of material.
How do I improve this print?
Oh, also just noticed in the full size image that the top layers don't seem to be fully "connected". How do I fix that?
[img]http://www.ironcreek.net/photos/_s/1024 ... 204124.jpg[/img]
FULL SIZE IMAGE
Settings:
Nozzle: 0.5
Layer height: 0.2
Bed temp: 90/100 (first/rest)
Extruder: 225/230 (first/rest)
Speed: Perimeters around 30mm/s; infill 50mm/s
bubbasnow
Re: "Blobbing"?
Post by bubbasnow »
looks good to me. you can calibrate your extruder to give it a better fill. delta arm blues can also cause issues with fill. and using slic3r it fills differently compared to kisslicer
int2str
Re: "Blobbing"?
Post by int2str »
bubbasnow wrote:you can calibrate your extruder to give it a better fill.
Is the procedure written down anywhere?
Can you point me to a HOWTO or something?
dpmacri
Re: "Blobbing"?
Post by dpmacri »
http://forum.seemecnc.com/viewtopic.php?f=54&t=1163
