h-1 help
Posted: Sun Dec 15, 2013 5:11 am
by martinezfrank95
help i bought a h-1 printer use put it together it came with 4 axis controller 3 motors 2 velleman one heated bed can someone tell me if the 4 axis is going to work. or is there something better out there that i can use in in its place. somethimng that i can plug in to a usb port instead of a printer port
Re: h-1 help
Posted: Sun Dec 15, 2013 6:35 am
martinezfrank95 wrote:help i bought a h-1 printer use put it together it came with 4 axis controller 3 motors 2 velleman one heated bed can someone tell me if the 4 axis is going to work. or is there something better out there that i can use in in its place. somethimng that i can plug in to a usb port instead of a printer port
Contact
[email protected]
Re: h-1 help
Posted: Mon Dec 16, 2013 3:54 pm
by Fiero2M6
The 4-axis controller will only work with a Mach3 or LinuxCNC. It must interface with the software using a parallel port. You can buy USB adapaters for ~$150, but they are not worth it for 3-D printing. It would be cheaper to just use conventional Reprap electronics (
http://reprap.org/wiki/List_of_electronics) instead of buying the USB adapter.
Bottom line is that you can use the Mach3 with the Velleman thermostats if you have a computer with a parrallel port. Otherwise, you should buy conventional Reprap electronics.
Re: h-1 help
Posted: Tue Dec 17, 2013 12:39 am
by wildideas1
Yes the 4axis works great with mach 3 and both vellemans, you operate the vell'S manually 1 to controll the hotbed and other the tip
I run 2 H1 and 1 delta any? I will be glad to help out
