3mm PLA E3D temps
Posted: Sun Dec 15, 2013 1:29 pm
Ive been printing some white (maybe Ultimachine, not super sure though) PLA on my 3mm E3D, and the temps I've been having to use don't make much sense...
I dont have a thermocouple to test it out unfortunately, but Ive been having to bump my temp way up to 250C to get good results and its confusing and bothering me. Ive used a 1.75mm E3D and some opaque orange PLA and i never had to go above 230C, and Ive used another 3mm E3D with this same PLA and I never had to go above 220C if I remember correctly. The Buda I used for a time I had to get to 205 to print with at fairly high speeds (same PLA), though the Buda does have a larger melting chamber. Ive been printing with Cura set to 70mm/sec and Slic3r with what I would call medium speeds (all averaging out to ~70+mm/sec), and a fan set to ~60% speed. Maybe this is right, but its bothering the crap out of me because it goes against about everything I know about this PLA.
Ive also printed Nylon without the Fan on the Slic3r speeds at 270C and it worked fairly well, though I probably could have done it at a higher temp...
