Reset signal changes baud rate - Repetier 0.90/Ubuntu 13.10
Posted: Tue Dec 31, 2013 12:26 pm
So, I'm printing off the SD card just fine but Repetier Host is giving me difficulty. I configured as in the Orion manual, and got all the way to issuing manual controls from RH. However, it seems that whenever I connect to the printer via USB, the reset signal brings the serial settings back to the default 250000 baud (Ubuntu wasn't playing nice until I turned it down to 115200.) I've been using the process described in the quick start guide to set the baud rate on the printer side - is this right? (Configuration -> General -> Baud Rate on the 0.83 firmware.)
Once I connect to the printer, it won't do anything else from the PC side. If I browse the configuration menu I can see that it's back to 250000 baud. Repetier starts to say "# Command waiting" for every manual command I issue, but doesn't report any errors or otherwise indicate than anything untoward is going on. Am I doing something obviously wrong? I'm trying to find mention of similar problems amongst the documentation and discussions but I've mostly turned up unrelated problems so far. Any help would be much appreaciated.
Happy new year,
~Joe
Happy new year,
~Joe
