[Solved] Filament getting stuck
Posted: Thu Jan 09, 2014 4:38 pm
by JonAdkins
Hey All,
For some reason my filament is getting stuck ( in the Hot End ) at various points in the print process. It's commonly happening around the same point in my prints ( layer 40 - 60 ) which leads me to believe that it might be a problem with retraction or with a bad slice. When it happens I have to take off the Hot End side Push-Fit and take pliers to forcibly remove the filament from the connector.
I initially thought that it might be the Bowden Tube as it bent possibly causing friction, however, I've taken it off and have tried to ensure it routes a different way when it bends and the issue still exists.
I haven't yet tried a different object or slicer on the same object to see if the issue persists.
What I'm wondering is whether the slice might be causing the filament to retract a few times in a short period and it ends up retracting deep enough into the Hot-End to no longer be meltable thus causing a jam?
I'm very new to 3D Printing and while I understand what the ultimate goal of retraction is, I'm wondering whether turning those settings down or off all together would be advisable to solve such an issue, or should I really be keeping those settings default and just try slicing with a different slicer?
I'm using Slic3r and its default retraction settings which are:
Length: 1mm
Lift Z: 0
Speed: 30mm/s
Extra Length on restart: 0mm
Minimal travel after retraction: 2mm
Retract on layer change: checked
Wipe while retracting: false
I'm also wondering whether this could be a symptom of improper temperatures? Should I try upping my temperature from 185?
I am going to be installing an E3D Hot-End in the next few days, but until then any advice that you Guru's could give would be greatly appreciated.
-jon
Re: Filament getting stuck
Posted: Thu Jan 09, 2014 4:58 pm
by barnett
If this is PLA filament, do you have a cooling fan blowing on the PEEK part of your hot end (the thinner part right above the heater block)?
Such a fan is required for PLA filament to prevent these jams.
If you're using ABS, then I would definitely print hotter than 185C, although the low temp would cause other problems besides jams.
Posted: Thu Jan 09, 2014 5:01 pm
Jon, what filament are you using? PLA or ABS?
Posted: Thu Jan 09, 2014 5:17 pm
by Orenfor
i have alittle experience with that , if you using ABS with high temp try to enable cooling fun , i know ppl will say not to do that , but for me it works ( i had this problem) put the cooling fan at 30% speed.
the other thing you can check is the tube that inside the hot end, i was heating the hotend so high without cooling at first and it make the tube get thinner so the filament didn't go well throw it...
Good luck with that....
Posted: Thu Jan 09, 2014 5:19 pm
by Orenfor
and one more thing , if you using ABS and still don't want to enable fan like every one here will say try to print a little faster, it can help too :)
Cheers
Posted: Thu Jan 09, 2014 5:54 pm
by JonAdkins
Eaglezsoar wrote:Jon, what filament are you using? PLA or ABS?
Sorry for forgetting to post this earlier.
I'm using PLA. I do have a Layer Fan and the PEEK fan currently installed.
I printed the suggested Shroud for the PEEK fan and have that installed and I'm using the layer fan that Gene suggested http://repables.com/r/171/
I am a bit curious about what % speed you're using for your layer fans. I've tried 50% and 100% and see no appreciable difference.
-jon
Posted: Thu Jan 09, 2014 6:37 pm
Try raising the temperature in 5 degree increments but you should not go over 215. Report back and let us know if raising the temperature made any difference.
Posted: Sun Jan 12, 2014 3:01 am
by enggmaug
I had similar issue recently. I thought it came from PLA, and was about to give up on PLA.
On my last try, in the middle of the print, I noticed the extruder kept extruding during few seconds. I ran through GCode near the layer having problems and found commands asking for extruding 100mm, 200mm, or even sometimes more than 500mm.
Because the filament can not possibly melt so fast, it does not extrude, and the extruder just digs a hole in it. Later on, the extruder cannot push the filament anymore, because of that very hole.
I then wrote a python script to analyse G-code, and replace crazy extruding commands. If a command asks more than 10mm, it will be replaced and saturated to 10mm. That solves the problem. However, I still have to try different slic3r settings to find the parameter causing this, because it only happens in my .2mm layer config.
If you are interrested in installing python, and giving it a try with my script, I can send it to you.
Posted: Sun Jan 12, 2014 6:35 am
enggmaug wrote:I had similar issue recently. I thought it came from PLA, and was about to give up on PLA.
I would be interested in that script.
Posted: Sun Jan 12, 2014 7:32 am
by enggmaug
Ok, then just let me comment my code for it to be understood easily, and, I'll share it.
Should I just copy the script code here, or give a link to a file hosted somewhere else?
Posted: Sun Jan 12, 2014 7:55 am
enggmaug wrote:Ok, then just let me comment my code for it to be understood easily, and, I'll share it.
I would copy the script code here by adding it as an attachment and thank you!
Posted: Sun Jan 12, 2014 8:45 am
by enggmaug
Ok, so you need to have Python (2.7) installed, and you can configure Slic3r to run this script after generating GCode.
This code would not run under python 3.x.
Just copy paste the code in a text file that you rename "WhateverName.py", and place it in a folder of your choice.
You can alternatively run it manually, by changing the path to the Gcode in the script.
Here is the script code :
#Script to analyse GCode and saturate Extruder commands to SATURATION value
#Guillaume Maugein - Jan 2014
import sys
import re
import os
import Tkinter as tkinter
import tkMessageBox as mbox
#if launched from Slic3r, the filename is passed in parameter automatically
#else, if launched manually, it will parse the file indicated thereafter
if len(sys.argv)>1 :
    filename = sys.argv[1]
else :
    filename = "C:/Users/Guillaume/AppData/Local/RepetierHost/composition.gcode"
#While parsed, modifications are saved to a temporary file in the same folder
#as parsed gcode file
tmpname = os.path.dirname(filename) + "tmp.gcode"
#SATURATION value (in mm)
SATURATION = 10.0
#Variables Initialisations
count = 0 #counting lines in GCode
MaxLine = 0 #Line with Max Extrusion value - for display only
MaxDist = 0.0 #Max Extrusion value - for display only
E = 0.0 #Current Line extrusion value
OldE= 0.0 #Changed Extrusion value of previous line
PreviousE = 0.0 #Actual Extrusion value of previous line
SupSat = 0 #Number of saturated lines - for display only
outputfile = open(tmpname,'w')
inputfile = open(filename,'r')
for line in inputfile:
    count = count + 1
    if line.count(";") > 0 : #Removing comments that could be troublesome
        tmpline = line[0:line.find(";")]
    else :
        tmpline = line
    Out = tmpline.split(" ")
    GCommand = (tmpline.count("G92") != -1) #Searching for G92 commands reseting Extruding distances
    if GCommand :
        for Command in Out:
            Command = Command.upper()
            if Command.count("E0") >= 1:
                E = 0.0
                OldE = 0.0
                PreviousE = 0.0
    GCommand = (tmpline.count("G0") != -1) or (tmpline.count("G1") != -1) #Searching for Extruding commands
    if GCommand :
        for Command in Out:
            CommandU = Command.upper()
            if CommandU.count("E") == 1 : #if there is an extruding command
               OldE = E
               E = float(CommandU[1:])
               Dist = E - OldE
               if Dist > SATURATION : #if Extruding more than SATURATION mm
                   if E - PreviousE > 0 :
                       print "Modified Line " + str(count)
                       print "   - Was Extruding " + str(E - PreviousE) + "mm"
                       E = SATURATION+OldE
                       line = re.sub(Command,"E{:.5f}".format(E),line)
                       line = line[0:line.find("\n")-1] + "; Modified by script \n"
                       SupSat = SupSat+1
                   else :
                       E = OldE + E - PreviousE
                       SupSat = SupSat+1
               PreviousE = float(CommandU[1:])
               if (Dist > MaxDist) : #Saving Maximum Extruding command (For display only)
                   MaxDist = float(Dist)
                   MaxLine = count
    outputfile.write(line) #Writting to temporary file
outputfile.close()
inputfile.close()
if SupSat > 0 : #If no command is saturated, there is no message
    window = tkinter.Tk()
    window.wm_withdraw()
    #Message to ask if you want to replace GCode or not
    if mbox.askyesno ('GCode Extruder Check',"Extruder Limite Reached : " + str(MaxDist) + " mm in Ligne nb : " + str(MaxLine) + ". \nReplace GCode ?") :
        os.remove(filename)
        os.rename(tmpname, filename)
        print str(SupSat) + " modified lines." #Message Nb of modified lines.
    else :
        os.remove(tmpname) #removing Temporary file
else :
    print "Clean Code."
If you need help with it, feel free to ask.
Posted: Sun Jan 12, 2014 9:18 am
Is it possible for you to post a "how to" on configuring Slic3r to run this script after generating the gcode? (some of us need a dummies guide).
Posted: Sun Jan 12, 2014 10:29 am
by enggmaug
You can set it up in Slic3r print settings - output options tab - as follows (just enter the path of the script as I did):
[img]http://imagizer.imageshack.us/v2/800x60 ... 2/cl0u.png[/img]
I believe I saw a way to launch a script after every Gcode generation, independently of the settings, but I could not find it anymore.
Posted: Sun Jan 12, 2014 10:37 am
Great! Just what we needed to know how to launch your script. Thank you!
Posted: Sun Jan 12, 2014 11:04 am
by enggmaug
If you do try it, let me know how it works, and if it helps you solve your stuck filament issue.
Posted: Mon Jan 13, 2014 4:02 pm
by JonAdkins
After running several tests with different filaments, speeds, temperatures my issue has essentially come down to a "Bad Slice" with Slic3r as I ran the same model through Kiss Slicer and everything worked beautifully.
It turns out that the issue was exactly what enggmaug pointed out where it was trying to extrude 100mm instead of 10mm and the hot-end was getting gummed up.
I've found that Slic3r handles manifold models quite well, however, when feeding it non-manifold models things tend to become quite dicey. This is understandable as slicing non-manifold models requires the Slicer to make several assumptions about what you actually want and the math just doesn't always work out for the best.
I found that Cura actually has the best support for non-manifold models in that it allows you to configure how sub-models and cavities are dealt with within the Expert Config section of the tool.
In my case I had created my own supports and baked them into my model file as I wanted to see what the difference would be between a custom support structure and the standard ones that are created automatically. My supports were made up of many interpenetrating posts and struts which ended up working out well from a removal standpoint, but obviously caused the software a bit of grief. In Cura I used Combine Everything Type-B which sounds like it only raycasts the models exterior while slicing, which is exactly what I needed.
The model ended up printing well in Cura, however, Cura doesn't appear to offer the option to set custom Extrusion Width which is a clear issue as I've calibrated my Extrusion Width and Flow as per Polygon Hell's tutorial ( http://forum.seemecnc.com/viewtopic.php?f=54&t=1163 ). I've since printed the same model in Kiss Slicer with stellar results.
I suppose the moral of the story is that every slicer is going to excel in different capacities and it pays to know all the slicers out there, it's really easy to run things through a few different slicers when you're having trouble and choose the one that works best.
The ultimate solution though, as enggmaug pointed out, is to understand enough of what's going on under the hood to at least figure out what the problem is and either ignore it and use a different slicer ( which is what I've done ), or fix it yourself and continue on.
Thanks for all the help with this issue, you guys make up a great community.
-jon
Re: [Solved] Filament getting stuck
Posted: Mon Jan 13, 2014 5:20 pm
by enggmaug
I have just been lucky enough to be near the machine when it tried to extrude more and more filament while not moving the plateform...
Is there a guide out there to help picking a slicer for a given model ?
The model I was trying to print when I found this problem was indeed manifold.
So I understand you recommend that whenever my script tells me slic3r is trying to extrude too much at a time, I should switch to KissSlicer ?
Posted: Tue Jan 14, 2014 12:31 pm
by JonAdkins
enggmaug wrote:I have just been lucky enough to be near the machine when it tried to extrude more and more filament while not moving the plateform...
I imagine that this bug will be fixed at some point in the near future as the random addition of zeros to the extrusion calculations is far from normal. I'm going to email the Slic3r developer my STL and GCode and hopefully he can track it down and address the issue. Seeing as over 50% of the community is using Slic3r I'm almost certain they already know about it.
For my issue changing up slicer's worked well, and after digging around various forums and such it really does seem like it pays to have at least a couple slicers installed and configured. I've had the most consistent results with Kisslicer with Cura being a close second. I do like Slic3r, however, some of my models have taken upwards of 4 hours to slice, which is a clear issue when Kiss and Cura can do the same job in less than a minute.
I've only started my journey in the world of 3D Printing and my opinion thus far is that the hardware side of things and the act of extruding filament in layers seems quite known from a development standpoint, however, the software is currently in its infancy. Most of the available slicing software seems to be programmer driven endeavors with little to no thought about the user-experience. This is where companies like Stratasys and 3D Systems are really trying to capitalize. They clearly have a team of engineers working on both the underlying tech and the user experience in an attempt to give users as pleasant of an experience as possible. They realize that the majority of people who are going to become interested in this technology simply want to feed a machine a model and have it come out with reasonable results, they don't want to mess with 30 magic numbers that work together in mysterious ways to produce a result.
Guys like us are always going to gravitate towards solutions that allow us to tweak and tune things to get the best results. For myself, the decision to build a Rostock Max wasn't a financial one, it was one that was aimed at being able to tune a machine to get the results I was looking for, not the ones that Stratasys decided were good enough for me.
My prediction is that an actual software company like Autodesk will swoop in and create commercial tools that produce results far better than anything out there. They'll start, as they already have, by partnering up with one of the big players and then quickly add support for the more DIY oriented printer community.
-jon
Posted: Thu Feb 06, 2014 8:49 am
Jon, nice work. Last year about this time I described and researched a similar issue I called hydraulic plugging. This was with the original Steve's extruder. I switched to KISS at the time and have no longer had the problem.
