Printer pausing in the middle of a build
Posted: Fri Jan 10, 2014 1:13 pm
by MashinoDesign
Hi Everyone,
I've been having some issues with my prints pausing in the middle of a build. This has happened when I slice a file using Slic3r and Cura. I am running the printer using a laptop. I've read that some of the default power settings on laptops have USB ports going to sleep after a while. Could that be a possible cause of my issues? I changed my settings and am running a build now to test it out. Anyone have any experience with this issue or any input? The odd thing is that I've had some longer builds run over night without any issues, but then I've had some pause while I was sitting right next to the machine.
Thanks in advance for your input,
Tom
Re: Printer pausing in the middle of a build
Posted: Fri Jan 10, 2014 1:25 pm
by dpmacri
MashinoDesign wrote:Hi Everyone,
Tom
I had a similar problem at one point. I just set my laptop to not sleep the HW (just the display) and the problem went away.
Posted: Fri Jan 10, 2014 1:39 pm
Tom
Hopefully it is as simple as dpmacri described in the above thread but if not what you are describing is known as the "repetier bug" and is a documented problem on this forum. Some have tried setting the layer height in the slicer to an odd size such as if you were using a 2mm height you would change it to 2.1. There is no known fix for it yet that I am aware of and the latest version of Repetier has not been out very long but they claim the paused printing problem has been fixed in the very latest version .91 Under the Orion subforum there is the latest upgrade of Repetier for the Orion but the decision to upgrade should not be taken lightly, you may end up having to do a complete calibration of your printer after you upgrade.
You are using a laptop and there are numerous power settings that need to turned off or adjusted in Control Panel. You don't the want laptop going to sleep, hibernating, turning off the hard disk, etc. Here are two links that discuss the pausing you are experiencing:
http://forum.seemecnc.com/viewtopic.php?t=2542&p=18918
http://forum.seemecnc.com/viewtopic.php?f=54&t=2144
See if anything in those threads have anything in common to the problems you are experiencing.
Posted: Fri Jan 10, 2014 2:07 pm
by MashinoDesign
Thanks for the replies. I haven't looked at the links you posted yet. However it just did it to me again. Here is the last few lines of the log. Anything jump out?
13:53:43.497 : N52408 G1 X23.405 Y-32.891 E7.06514 F1800 *11
13:53:43.501 : N52409 G1 X23.405 Y-32.298 E6.78323 F2400 *12
13:53:43.505 : N52410 G1 E2.56514 F1200 *37
13:53:43.555 : N52411 G1 Z2.25 F3000 *15
13:53:43.559 : N52412 G92 E0 *103
13:53:43.559 : N52413 G1 X15.232 Y-31.526 F3000 *68
13:53:43.563 : N52414 G1 Z1.75 F3000 *12
14:03:56.711 : N52415 M105 *0
14:03:58.563 : N52416 M117 ETE 6h26m35s *22
14:03:58.564 : N52417 G1 E4.5 F1200 *34
14:04:14.949 : Delta overflow:16830068
14:04:14.953 : Delta overflow:33357824
14:04:14.953 : Delta overflow:50137055
14:04:14.953 : Delta overflow:16582624
14:04:14.953 : Delta overflow:100353787
14:04:14.953 : Delta overflow:134124336
14:04:14.957 : Delta overflow:167512907
14:04:14.957 : Delta overflow:-65536
14:04:14.957 : Delta overflow:167395072
14:04:14.961 : Delta overflow:-346367
14:04:14.961 : Delta overflow:118597066
14:04:14.961 : Delta overflow:1412998891
14:04:14.961 : Delta overflow:14502125
14:04:14.961 : Delta overflow:154730747
14:04:14.965 : Delta overflow:-37975056
14:04:14.966 : Delta overflow:14134497
14:04:14.966 : Delta overflow:16777216
14:04:14.969 : Delta overflow:1391823952
14:04:14.969 : Delta overflow:16403540
14:04:14.969 : Delta overflow:1341425403
14:04:14.969 : Delta overflow:1450899456
14:04:14.969 : Delta overflow:156263168
14:04:14.974 : Delta overflow:1559491584
14:04:14.974 : Delta overflow:-537629376
14:04:14.974 : Delta overflow:-367798
14:04:14.978 : Delta overflow:1358144970
14:04:14.978 : Delta overflow:1429661952
14:04:14.978 : Delta overflow:-15348553
14:04:14.978 : Delta overflow:-373905974
14:04:14.982 : Delta overflow:1446525600
14:04:14.982 : Delta overflow:15318690
14:04:14.982 : Delta overflow:171442424
14:04:14.982 : Delta overflow:-71577184
14:04:14.986 : Delta overflow:1190384703
14:04:14.986 : Delta overflow:-65536
14:04:14.986 : Delta overflow:-889986444
14:04:14.986 : Delta overflow:-513169
14:04:14.990 : Delta overflow:-441061120
14:04:14.990 : Delta overflow:-852119552
14:04:14.990 : Delta overflow:-14724211
14:04:14.990 : Delta overflow:1358140928
14:04:14.994 : Delta overflow:-151742082
14:04:14.994 : Delta overflow:13973630
14:04:14.994 : Delta overflow:-640111360
14:04:14.994 : Delta overflow:184539794
14:04:14.998 : Delta overflow:13958928
14:04:14.998 : Delta overflow:-16748032
14:04:14.998 : Delta overflow:1467547392
14:04:15.002 : Delta overflow:168725502
14:04:15.002 : Delta overflow:1559457792
14:04:15.002 : Delta overflow:-407091717
14:04:15.002 : Delta overflow:367724289
14:04:15.002 : Delta overflow:436188155
14:04:15.006 : Delta overflow:1794309833
14:04:15.006 : Delta overflow:595930624
14:04:15.006 : Delta overflow:637513723
14:04:15.010 : Delta overflow:-118338363
14:04:15.010 : Delta overflow:804522496
14:04:15.010 : Delta overflow:2147155968
14:04:15.010 : Delta overflow:1223910511
14:04:15.010 : Delta overflow:13968384
14:04:15.014 : Delta overflow:1375380938
14:04:15.014 : Delta overflow:-688736160
14:04:15.015 : Delta overflow:215281152
14:04:15.018 : Delta overflow:-33685504
14:04:15.018 : Delta overflow:171859424
14:04:15.019 : Delta overflow:-546598
14:04:15.019 : Delta overflow:33030144
14:04:15.023 : Delta overflow:1408458992
14:04:15.023 : Delta overflow:16130027
14:04:15.023 : Delta overflow:16801792
14:04:15.023 : Delta overflow:-591671808
14:04:15.027 : Delta overflow:197262337
14:04:15.027 : Delta overflow:167223296
14:04:15.027 : Delta overflow:1261829888
14:04:15.027 : Delta overflow:-11280384
14:04:15.031 : Delta overflow:-218103808
14:04:15.031 : Delta overflow:-890040336
14:04:15.031 : Delta overflow:-509266
14:04:15.031 : Delta overflow:16252928
14:04:15.035 : Delta overflow:201326336
14:04:15.035 : Delta overflow:217316592
14:04:15.035 : extruder 0: temp sensor defect
14:04:15.036 : heated bed: working
14:04:15.039 : Printer set into dry run mode until restart!
Posted: Fri Jan 10, 2014 2:29 pm
I contacted a higher level of support, they will be getting back to us on this problem.
Please let me know what SeeMeCNC support determines the problem to be.
