Two quick-change hot ends...
Posted: Wed Feb 05, 2014 12:07 pm
Aluhotend:
[img]
http://www.geneb.org/rostock-max/aluhotend-1.jpg[/img]
[img]
http://www.geneb.org/rostock-max/aluhotend-2.jpg[/img]
"Real" J-Head:
[img]
http://www.geneb.org/rostock-max/j-head-1.jpg[/img]
[img]
http://www.geneb.org/rostock-max/j-head-2.jpg[/img]
They're using my variant on the Trick Laser j-head mount. I've added strain relief lugs and I wired it using solid core wire and a four pin quick disconnect. The connector is the same type that's used on the RAMBo & stepper motors.
The modified files I sent back to Brian include a deeper and wider relief throat so that the wire-tie won't be required.
Re: Two quick-change hot ends...
Posted: Wed Feb 05, 2014 3:39 pm
geneb wrote:Aluhotend:
The Aluhotend is not really discussed on this forum. Can you tell us how it works with PLA and ABS and is it as good as the E3D?
Posted: Wed Feb 05, 2014 4:17 pm
by Nylocke
Looks just like the Magma from trinity labs... I know someone was ranting about it earlier...
Posted: Wed Feb 05, 2014 4:27 pm
I haven't used either one.
From what I've read, all-metal hot ends are problematic with PLA so I won't even bother. That's why I got the j-head.
I haven't put either one into service yet.
Posted: Wed Feb 05, 2014 4:33 pm
geneb wrote:I haven't used either one.
I going to see if I can find some info on the aluhotend and report what I find.
The one hotend that is all metal is not rated to high and that is the Magma.
Posted: Wed Feb 05, 2014 4:47 pm
Forget the Aluhotend. It looks to be an all metal hotend but it is not. It has PTFE liners and the max recommended temperature is 245C.
Posted: Thu Feb 06, 2014 10:23 am
I emailed him to see which version I got - I bought it months ago.
I'm gonna be hugely annoyed if it's got a liner.
Posted: Thu Feb 06, 2014 10:45 am
geneb wrote:I emailed him to see which version I got - I bought it months ago.
Prepare to be hugely annoyed.
Posted: Thu Feb 06, 2014 12:01 pm
by Nylocke
I'm pretty sure that's a magma 3mm adapted to 1.75 with a Teflon liner..
Posted: Thu Feb 06, 2014 1:26 pm
It's not a Magma. It's made buy a guy I know in .au.
I wasn't aware of the liner - I wanted it so I could print "exotic" high-temp materials.
I can still use it though - I'll just throw it on my LulzBot TAZ - I've never been happy with the Budaschnozzle 2.0 hot end that it's got anyway.
