Calibrating: how far to take it?
Posted: Thu Feb 06, 2014 8:02 pm
Ok, Got through my first round of Calibration. Went pretty well until I crashed the head trying to print. (still needs to be resolved).
Got me considering though, Calibration appears to be a moderately regular thing.
So I dreamed up a little gizmo to help with the style of calibrating suggested in the build manual.
I find by the time I get around to the next point of contact, I have lost the sense of how tight the previous one was.
Doing it crudely went fine, but as I tried to get it tweeked more and more... it got hard.
Not sure if this is taking it too far and it wouldn't matter...
It is based off of the old scale to measure the weight of fish. but this would measure the tension built up by the friction between the head and build plate.
Uses a common Pen Spring to generate the tension. Marked on a 1mm scale.
Test for Starting friction, and sliding friction.
-- Pull on it and observe point of release
Test for Sliding friction
-- Pull on it and observe reading as it slides through the pinch point.
Write both down and repeat. take the average.
Shoot for the same average on all 4 tests
I think to really get it sensitive enough, a lighter spring would be in order, but I cannot think of one that is real common.
if this isn't overkill, anybody have an idea of a lighter spring? I suppose, it could be printed if it were designed different?
I think I will change it so the scale is easier to read.
[img]http://www.neurascenic.com/show/FrictionScale.png[/img]
Cheers!
Cheers!
