Calibrating your H-1
Posted: Mon Apr 02, 2012 7:06 pm
Starting points from the Yahoo site (read most of the threads)
Starting Points:
Use
[url]http://richrap.%20blogspot.%20com/2012/%2001/slic3r-%20is-nicer-%20part-1-settings-%20and.html[/url]
As for the steps per mm on the extruder, I calculated 284/mm @ 1/8 step.
Remember this is NOT filament out, but filament in. It takes 284 steps to feed
in 1mm of filament into the extruder. For 1/16 its 568 steps/mm. I used the
method described on the wiki page to calculate this. Others have also gotten
values fairly close to that.
For the other axis, the values are (at 1/8 step):
X axis - 1600/50.8 = 31.50 steps/mm
Y axis - 1600/50.8 - 31.5 steps/mm
Z axis - 64000/25.4 - 2519.69 steps/mm
For 1/16 just double the values - 3200/50.8 (X&Y) and 128000/25.4 (Z).
-Mike
Refinement:
Use the RepRap Calculator and Tips with your experience.
http://calculator.josefprusa.cz/ This fine calculator was designed with many years of experience of Josef Prusa of Mendel Prusa fame.
Starting Points:
Use
-Mike
Refinement:
