misaligned layers
Posted: Wed Feb 12, 2014 4:34 pm
by MashinoDesign
Hi Everyone,
I've been working on trying to get my Orion dialed in. When I run a 20m test cube, the bottom layers look fine, but when it starts to build the walls, they look like they are misaligned. This happens no matter what slicer I use. Attached is an image of what I am seeing. Anybody have any suggestions?
Thanks
Tom
Re: misaligned layers
Posted: Wed Feb 12, 2014 9:31 pm
What kind of filament and what temperatures are you using?
Posted: Thu Feb 13, 2014 9:10 am
by MashinoDesign
Sorry about that. I was in a hurry last night when I made my post. I'm using ABS at 240 degrees.
Posted: Thu Feb 13, 2014 9:26 am
Try running the ABS at about 215-220 and see how it works. At 240C, you're nearly to the thermal limit of the PEEK thermal break in the hot end.
Posted: Thu Feb 13, 2014 9:48 am
by MashinoDesign
Ok, I changed my hot end temp to 220 degrees on this one. Still getting the same thing. See picture. This is sliced using 1 peremiter shell. I am going to try this again in Kisslicer to see if it behaves differently. This was sliced using Simplify.
Posted: Thu Feb 13, 2014 10:06 am
by Orenfor
it's look like slicer problem, try to print another cube, maybe the stl file have errors....
and btw use G28 at the end of the print, i can see that in the right upper corner the printer sfinish the printing and stay at the same point , G28 at the end of the printing will make your all axis go home as it finish the printhing
Posted: Thu Feb 13, 2014 10:30 am
by MashinoDesign
So I guess my issue was the slicer that I was using. Kisslicer provided a nice looking test cube. Now on to figure out why my cube is about 1.5mm too small in the x and y direction.
Posted: Thu Feb 13, 2014 11:06 am
by lordbinky
I just adjust my delta rod length by the % off it is to change the scale of the X & Y .
Posted: Thu Feb 13, 2014 11:09 am
by MashinoDesign
Can you enlighten me a little bit on this process? My 20mm cube is measuring 18.65mm.
Posted: Thu Feb 13, 2014 11:16 am
by MashinoDesign
I took a look at the EEPROM settings. Is Diagonal Rod Length what you are referring to? My rod length is set to 178.00mm, so does that mean that I need to scale mine by approximately 7%? 20/18.65?
Posted: Thu Feb 13, 2014 11:38 am
by lordbinky
Yeah, that's the one you change. I don't remember if it is (Real Size/Intended Size)*Diagonal Rod Length or (Intended Size/Real Size)*Rod Length, just write the result for both and if you choose the wrong one it'll get smaller instead of larger :D .
Posted: Thu Feb 13, 2014 11:44 am
by Orenfor
did you check that nozzle high ? did it fix with the EPROM high ?
Posted: Thu Feb 13, 2014 11:47 am
You guys need to be careful when changing things on the Orions. They're calibrated and test prints are run before they ship each one. You should back out any firmware changes you've made and contact support directly for guidance.
Posted: Thu Feb 13, 2014 12:38 pm
by lordbinky
Woops, wasn't thinking about it being an Orion... Gene's suggestion is definitely the way to go.
