the link gives back a 404 error anywhere else I can get it from?
Tom C
repetierMAX link is broken on GITHUB
MAX V1
Corvair750
V6 Hotend
Robo 3D
Flashforge creator
Corvair750
V6 Hotend
Robo 3D
Flashforge creator
Re: repetierMAX link is broken on GITHUB
https://github.com/seemecnc/Repetier-091-ROSTOCKMAX is working fine.stonewater wrote:the link gives back a 404 error anywhere else I can get it from?
Tom C
Is the .091 version of Repetier the one you were looking for?
this is the link out of the ass.manual:
http://github.com/seemecnc/RepetierMAX.
so that will have to be appended in the assembly manual at some point in time
MAX V1
Corvair750
V6 Hotend
Robo 3D
Flashforge creator
Corvair750
V6 Hotend
Robo 3D
Flashforge creator
The only place I see that "link" is when the manual shows what you will see in the display.stonewater wrote:this is the link out of the ass.manual:
It is not listed as a link that you should goto to download versions of software.
When you need to download something the best link to goto is http://www.seemecnc.com then
select downloads and then the appropriate printer.
okee dokee
MAX V1
Corvair750
V6 Hotend
Robo 3D
Flashforge creator
Corvair750
V6 Hotend
Robo 3D
Flashforge creator
here is the text from the manual;
There are some simple changes you'll need to make to the RAMBo's firmware as part of the
calibration and configuration process. In order to send your changes to the RAMBo, you'll need to
download and install the Arduino IDE. The firmware on the RAMBo is called Repetier and requires
the version of the Arduino IDE to be at least 1.0. You can download the current release of the Arduino
IDE from this location: http://arduino.cc/en/Main/Software. At the time of this writing, version 1.0.5
was the current stable release.
The firmware for the Rostock MAX can be downloaded from this location:
If you click on the “Zip” button on that page, it will create a zip file of the current code and you
can download it all in one go instead of picking each file. I would recommend you download the
firmware and unzip it so you can tweak it if need be.
so I copied that into my browser
the same url is listed on the downloads page
MAX V1
Corvair750
V6 Hotend
Robo 3D
Flashforge creator
Corvair750
V6 Hotend
Robo 3D
Flashforge creator
You are correct in what you say now. This may require a change but that is up to the author, Gene.
I'm sure he will read this and take care of it if he feels that it is necessary.
Because it doesn't appear that the .83 firmware is directly available (other than grabbing the whole RostockMAX repo), I'm not going to update the link - the kits shipped from this week forwards will be equipped with the .91 firmware anyway, which requires a whole new calibration process and NO tweak/compile grinding.
