Broken Thermistor?
Posted: Tue Feb 18, 2014 12:34 pm
by analog_banana
I can't heat my hot end up today..
Repetier is reporting the hot end temperature as -20 something degrees..
That would be a broken thermistor most likely?
Does anyone know a way to test a thermistor?
I have a "J-head" on it's way to me, so at least I have an alternative, but I will need a way to mount it on the rostock max.
Re: Broken Thermistor?
Posted: Tue Feb 18, 2014 12:54 pm
by Woolf
measure the thermistor with an ohmmeters, but when Repetier shows -20° then I think that the thermistor is really broken. Have you another Thermistor to test it?
look this, How i mount my J-Head
http://forum.seemecnc.com/viewtopic.php ... 0&start=10
Posted: Tue Feb 18, 2014 1:29 pm
by analog_banana
Thanks - I tested the resistance.
the bed thermistor measures a healthy 100k
the hotend thermistor measures 1.9meg??
To the bin it goes!!
Failed components so far:
PSU - faulty batch
Extruder - orginal replaced by vendor on his advice.
Bowden Tube: mechanical faliure
Thermistor - failed - blown??
It was really lucky I happened to order a Jhead this morning on a total whim,
so I will have a spare thermistor soon.
Posted: Tue Feb 18, 2014 1:30 pm
by Jimustanguitar
-20 is possible... Remember that zero doesn't mean zero
**edit... I meant that a thermistor could theoretically report that temp, not that you live in a freezer!
Probably a damaged thermistor or loose wire/connection though.
Posted: Tue Feb 18, 2014 1:40 pm
analog_banana wrote:I can't heat my hot end up today..
There are several mounts on Thingiverse, just do a search while on Thingiverse for jhead mount rostock
Posted: Tue Feb 18, 2014 1:48 pm
by analog_banana
Thanks Jim,
As far as I know I've been measuring in Centigrade and looking at centigrade in Repetier.
Even accounting for the temperate British Climate, -20 is a bit outside standard room temp. range.
Especially when the bed reports +22
I checked the thermistor at the business end - the actual thermistor wire pigtails -
It's giving a really wierd resistance measurement compared to the bed thermistor.
I don't trust it!
Posted: Tue Feb 18, 2014 1:51 pm
by analog_banana
Thanks Eaglez.
Printing upgrade parts is not an option for me right now.
I've never really had much luck printing anything except test cubes, and right now I can't even extrude.
But maybe I can find someone local to print one for me..
For now I will just try and get a working thermistor in the old hotend.
