Suddenly Problems -G-Code running extruder backwards@hispeed
Posted: Tue Feb 25, 2014 2:40 pm
by travelnaut
After importing the slic3r settings from the download section I am having intermittent issues with the printer.
When I run the G-code produced by slic3r the machine beeps a few times, moves to begin the first layer and then the extruder runs backwards at a high rate of speed. I turn it off at this point, and sometimes when I rerun the code its fine.. other times its does the same thing.
really scratching my head here.
Re: Suddenly Problems -G-Code running extruder backwards@his
Posted: Sun Mar 02, 2014 11:38 am
by kometen
I have the same problem.
Make sure that your extruders temperature is just above the setting in the gcode before you press RUN.
br
Poul
Posted: Sun Mar 02, 2014 12:15 pm
by enggmaug
what firmware do you run ?
is there anything special in the GCode ?
