Overhead EZStruder Motor Extension
Posted: Wed Feb 26, 2014 8:36 pm
by kittka
Is it possible to buy an pre-made extension for the Nema motor that has the polarized connectors already on? I've tried to make my own for the overhead extruder motor without much luck -- the connections are very finicky and if I jostle the cord the motor stops extruding. Right now I have to run with the bay door open or else the cord acts up.
Re: Overhead EZStruder Motor Extension
Posted: Wed Feb 26, 2014 8:39 pm
by AndThenSome09
Shouldn't give you much trouble if you pick up some JST connectors and use the supplied wiring. What part is it that you are having a hard time with?
Posted: Thu Feb 27, 2014 9:58 am
You don't use JST connectors on the stepper motors.
You need to use a four pin, latching polarized connector.
See this page:
http://www.hansenhobbies.com/products/c ... in_lp_1x4/ - the first two entries on the page are what I use for the extensions.
Posted: Thu Feb 27, 2014 9:54 pm
by AndThenSome09
Well....... I just used two JST connectors and matched the colors
.... is that bad??
Posted: Fri Feb 28, 2014 4:49 am
AndThenSome09 wrote:Well....... I just used two JST connectors and matched the colors
.... is that bad??
Different strokes for different folks. As long as it works you didn't do bad. Most of us would have used the type of
connector that Gene pointed out but it is your printer and use can use what ever connector you want as long as it works.
Posted: Fri Feb 28, 2014 9:59 am
...and keep in mind I'm VERY OCD when it comes to my wiring.
Posted: Fri Feb 28, 2014 3:36 pm
by AndThenSome09
just making sure I didnt upset the printing gods or anything!! lol
I just used what I had on hand
But I would like to know what is giving him such a hard time though so we can maybe help, I dont think anywhere sells any extension cables already made for you, could be wrong I suppose but I don't think so.
