Rambo fan issue
noddynomolos
Rambo fan issue
Post by noddynomolos »
Dear Group,
I have one of the old Rambo boards and am presently running Repetier 0.85b on the Repetier Sketch_Mar02a firmware.
I have not upgraded to the latest firmware.
Background info:
Since installing the EZstruder I have run into a brick wall... the hob gear eats through the filament and makes a real mess. This is due to the hotend jamming. When I the filament out of the hotend there is a visible thickening on the leading end of the filament. I have checked the hotend with a thermocouple and it is running about 5 degrees C above my Repetier temperature read out. I have recently replaced the nozzle with the new variation. I have also adjusted the teflon tubing to reconfigure it for the new nozzle (though have a further question about that).
Fan /Rambo issue:
I have acquired a 40mm 12v fan and plugged it into the Fan0 port.. From Repetier I ran the m106 command and got no response. I then moved the fan to the Fan1 port and tried the m106 command and no response.. On another thread I had read to use m42 p6 s255 so I tried that as well on both Fan0 and Fan1..
There is a small red LED that lights up on the rambo just below the heat0 port and above the jumpers... Further, I can turn this same LED on and off with the fan button on the Repetier control (in the manual tab).
Questions:
Is there a jumper I am missing on the board?
Is there a software command I must add to the firmware?
Should I even bother with the rambo and just run directly off the power supply?
Any suggestions would be greatly appreciated?
Yours,
Don S
Re: Rambo fan issue
What is the fan being used for and what type of filament are you using that plugs the hotend?
In addition what printer are you using?
noddynomolos
Re: Rambo fan issue
Hi Eagle,
I have a RostockMax and am printing in ( good quality) ABS.
I have some PLA but have not tried printing with it yet.. I figured one challenge at a time :)
The fan will be mounted on the hotend once I work out the power (to fan) situation.
I was reading another thread that talked about the teflon tube possibly being the issue (narrowing due to over heating and build up). So I will pull the tube and carefully run a dremel through it to remove any build up..
Re: Rambo fan issue
There is no build up in the tube - if the PTFE liner gets over heated, it will shrink a small amount, just enough to prevent filament from passing through it - you need to replace it if it's in that condition.
If the fan is known good (tested) and you use FAN0, the fan slider in Repetier-Host should activate it. M42 P6 255 will turn on the fan if connected to FAN1.
If you're seeing the LED lamp for HEAT 0 coming on when you move the fan slider, try connecting your fan to it - if the fan runs off HEAT 0, you've got serious pin configuration issues going on.
AFAIK, there is no known Repetier firmware version named "Sketch_Mar02". What _version_ of the firmware are you using. Note that if you're using v0.85 of Repetier Host, you're about 10 versions out of date. It's currently at 0.95F.
