Multiple Extruders - Why?
Posted: Thu Mar 06, 2014 11:36 am
[Edited - twice]
I've followed all of the dual and multiple extruder threads and while it is attractive, I thought I would explore its purpose and rationale.
From common sense, I see the following benefits:
Speed - Two heads means more area printed. Slicing software can split the job between two extruders.
Colors - Some software can print multiple colors. Some for specific layers, regions on the print, and different colors on perimeters and infill.
Materials - While I haven't seen much on it yet, I assume you can print different materials (like nylon on the outside and ABS on the inside, or as DBMacri/ToyGuy say printing with dissolvable support material)
Multiple Parts / Print Regions - Related to speed, you can print more than one part, each using a different extruder. I assume the same things apply, more than one part, more than one material, more than one head **.
Nozzle Flexibility - You might choose to have available different nozzle sizes [JimsGuitar] to print non-critical areas with one size and critical with a finer size.
Are there any other reasons to adopt dual extruder/heads?
While we're early at it, I'm still trying to grasp the scope of it all.
** This begs different questions - mainly about the concept of homegeneousness:
1. Different Heads - I've seen configs with an E3D and a stock Rostock head. I didn't look into the specific config but I have to assume it would be difficult to homogenize performance between the two. I assume you can just choose or possibly use both in a single print.
2. Different Materials - If you've printed for a while with different reels, you have different performance almost on a reel by reel basis. How do you handle it?
3. Different parts - some parts are no brainers but if you're doing a multi-part print, print behavior is not on a layer by layer basis, it's frequently part by part. Does a dual extruder make a difference here? Can using one ameliorate some of the issues you might have?
Apologies for the length, any of you people with two or more heads, I'd sure like to hear your thoughts!
