(Solved) Extruder "clicking" after printing
Lasivian
Post by Lasivian »
I am getting a tiny jerk and a click after I print things.
Triffid_hunter in #reprap said this is likely due to the stepper driver overheating.
But I am seeing that on the Rambo the current is set digitally not with a pot. So I am assuming it is correct.
Suggestions/ideas?
Thanks
EDIT: The thermistor seems to be off and the heat was too low (Even when it says 210c) for the .35 nozzle so the motor kept trying to force the filament.
I suppose this should be moved to the troubleshooting forum.
Re: Extruder "clicking" after printing
Edited, superceded.
I wouldn't reduce it at all. I'd add a cooling fan to the back wall of where the RAMBo is mounted, or print that neat fan shroud that Chrissi designed that fits in the LCD door.
Lasivian
Post by Lasivian »
geneb wrote:I wouldn't reduce it at all. I'd add a cooling fan to the back wall of where the RAMBo is mounted, or print that neat fan shroud that Chrissi designed that fits in the LCD door.
Do you have a link to this at all? I cannot seem to find it.
Thanks
Lasivian
Post by Lasivian »
Eaglezsoar wrote:Edited, superceded.
that was good info, why did you remove it?
Thanks
Thanks
Because it was superseded by others who apparently had better ideas.
Hey Chrissi! Can you post a link to that slick LCD door fan shroud you designed? I can't find the link either. :D
Lasivian
Post by Lasivian »
I finally found it
http://forum.seemecnc.com/viewtopic.php ... 104#p31104
For now tho leaving the LCD door open seems to give it enough air.
