My Rostock Max 1st gen upgraded
Posted: Wed Mar 12, 2014 2:00 pm
by Print_This
Nothing to exciting just a test run vid
Have an upgraded 1st gen, its been printing great accept recently i had a (hot end ) fan shroud melting issue not sure why,
it was made from ABS but still heated enough to drip down, anyways i printed a new one and did my yoda head test,
upgraded EZStruder and heat bed upgrade
top mounted filament
here is a vid i just made showing the old hot end fan shroud and the new one attached doing a teest run on yoda head
.3mm layers
50mm sec speed
PLA orange 200/60 bed
http://youtu.be/fXHByyzLxxA
Re: My Rostock Max 1st gen upgraded
Posted: Wed Mar 12, 2014 2:42 pm
That looks like the shroud for the peek fan. Do you ensure that the peek fan is on 100% when the hotend is hot?
The peek fan is the most important fan on the printer and must be on when the hotend is hot.
Posted: Wed Mar 12, 2014 6:12 pm
by bubbasnow
where did you get the orange arms?
Posted: Wed Mar 12, 2014 6:48 pm
by Print_This
Eaglezsoar wrote:That looks like the shroud for the peek fan. Do you ensure that the peek fan is on 100% when the hotend is hot?
the fan always comes on when i print for sure, actually all 3 are always on when i print etc. the shroud that slightly melted could have been effected as i noticed it wasnt all the way snapped into the slot. but either way everything seems fine with new shroud on and i will monitor it.
Posted: Wed Mar 12, 2014 6:49 pm
by Print_This
bubbasnow wrote:where did you get the orange arms?
oh was probably because it was very bright in here that they may have looked orange in the video, they are red though.
Posted: Wed Mar 12, 2014 7:35 pm
by Print_This
i had thought about the fan after my last post. one thing i notice is when i print file ( load ) the peak fan doesn't come on till the temps are reached and printing has started. but dont i want the peak fan to come on soon as the hot end starts to warm up?
so my question is if i use a g-code command in my kisslicer when slicing the file will it start the fan soon as warm up starts? or do you have another way of doing it?
thanks again
Posted: Wed Mar 12, 2014 8:33 pm
by AndThenSome09
If you have the peek fan hooked up to Fan0 then with SeeMeCNCs Repetier firmware it should turn on as soon as you start the machine.
It's something in Configuration.h of the firmware to set the fan to always be on.
Maybe you can change:
#define EXTRUDER_FAN_COOL_TEMP 40
to this:
#define EXTRUDER_FAN_COOL_TEMP 0
Then the fan should be on as soon as the hot end is on.
IDK, but that is what I would do if it were me.
Posted: Wed Mar 12, 2014 9:21 pm
by Print_This
AndThenSome09 wrote:If you have the peek fan hooked up to Fan0 then with SeeMeCNCs Repetier firmware it should turn on as soon as you start the machine.
to this:
cool, thanks for the response, i am looking to see if its hooked up to Fan0 and go from there, i appreciate the insight.
Posted: Wed Mar 12, 2014 9:27 pm
Except it's not Fan 0, it's Heat 1.
Fan 0 is the layer fan and is controlled by either an M code or the fan slider in Repetier-Host.
Heat 1 is used for the PEEK fan. It turns on with the hot end and will automatically turn off when the hot end temperature falls below 50C.
Posted: Thu Mar 13, 2014 4:57 am
by McSlappy
The finish looks nice, what are your settings for retraction?
Posted: Thu Mar 13, 2014 6:41 pm
by Print_This
McSlappy wrote:The finish looks nice, what are your settings for retraction?
hi thanks, the orange hides some detail away for sure. couple overhang issues under chin and tip of er but overall pretty satisfactory for orange PLA ( its a pain in the butt so far)
was .3mm layers
2 loops
wipe on
destring on
20% infill
skin thickness .75mm
z lift 1mm
.165 filament measured
50mm sec speed cut back 90% manual control
Posted: Fri Mar 14, 2014 12:46 am
by Print_This
printed the hollower pyramid for the first time tonight, and was pleasantly impressed with the quality!
http://youtu.be/-rHaPvH5OlY
Posted: Fri Mar 14, 2014 6:58 am
Print_This wrote:printed the hollower pyramid for the first time tonight, and was pleasantly impressed with the quality!
That is one of the best prints of that part that I have seen!
Very good job!
Posted: Fri Mar 14, 2014 7:07 pm
by Print_This
Eaglezsoar wrote:Print_This wrote:printed the hollower pyramid for the first time tonight, and was pleasantly impressed with the quality!
Very good job!
hey thanks! i have been having fun for sure, the next piece i printed was a gyro cube,
Posted: Sun Mar 23, 2014 11:49 am
by Print_This
so for now i just added the M106 command to the prefix code in kisslicer and fan comes when hotend comes on, i will see about hooking it up directly to heat 1 later on.
Posted: Wed Apr 09, 2014 1:56 pm
by Bluemalu
Excellent print, very nice job and no cooling fan for the filament. I've not managed one as tight as yours, been thinking it needed cooling, obviously not. Once agai, good job...
Posted: Sun Apr 13, 2014 2:28 am
by Print_This
Bluemalu wrote:Excellent print, very nice job and no cooling fan for the filament. I've not managed one as tight as yours, been thinking it needed cooling, obviously not. Once agai, good job...
i appreciate the comments, every day i learn something new, its been a blast! i love this Rostock Max
Posted: Mon Apr 14, 2014 8:42 am
by guanu
just to re-say what gene did... the peek fan should be wired to heat1 on the rambo... the wiring (if the green wire connectors are on the top) should go like this:
(from left to right)
Hotend -, + Layer fan -, + Peek fan -, + No connection -,+ Heated Bed -, +
and with the .91 firmware, as gene said, the peek fan will come on at the same time the hotend does, and will remain on until the hotend temp drops below 50c
Guanu
Posted: Mon Apr 14, 2014 10:11 pm
by Print_This
guanu wrote:just to re-say what gene did... the peek fan should be wired to heat1 on the rambo... the wiring (if the green wire connectors are on the top) should go like this:
Guanu
thanks for the tips. im using .80 maybe when i update in the future i might change, in the meantime adding the m106 to the prefix gcode puts fan on whenever hot end is on for a print job.
