Rostock MAX PTC Fittings Broken
Posted: Mon Mar 17, 2014 10:10 pm
by GeraldO
Hey guys,
I brought this up in IRC but I just wanted to post about sourcing replacement PTC connectors. I've e-mailed SeeMeCNC for replacements but it looks like they're sold out in the web-store.
Searching through the forums, I think I've found the correct size and threading for the connectors and found something which should work: http://www.mcmaster.com/#5225k503/=r525w4
Will this be a suitable replacement for the stock PTC connectors? I kind of wish that the original PTC connectors lasted more than the first weekend of real printing but oh wells!
Edit: spelling
Re: Rostock MAX PTC Fittings Broken
Posted: Mon Mar 17, 2014 10:40 pm
Yes, those will work.
Posted: Wed Mar 19, 2014 12:16 pm
by GeraldO
Awesome, SeeMeCnC is sending me some replacement fittings :)
Posted: Wed Mar 19, 2014 12:25 pm
by joecnc2006
I like the ones SeeMeCNC has the blue release is easier to push.
Maybe they will add them to their store also. Would not hurt to keep a couple on hand.
Posted: Wed Mar 19, 2014 12:33 pm
The blue ones are really problematic. They're the ones that like to break and drop little bits of metal into your hot end. :) The new grey capped ones hold better and do NOT want to let go. You're better off unthreading the fitting than trying to make it let go. :)
Posted: Wed Mar 19, 2014 12:52 pm
by bubbasnow
yea the blue ones, its not a matter of "if" they fail, but when... and its usually in a 10hr+ print while your sleeping. you will come downstairs and have a spaghetti mess. Save yourself the headache and chuck those out!
Posted: Wed Mar 19, 2014 1:21 pm
by MrPTrog
We use SMC and Festo fittings at work. They are used primarily for connecting air lines to air cylinders. They hold 0.6MPa (87psi) cycling 100,000+ times a day. I've never seen one fail. So after my 5:00am spaghetti floor pile I sourced some on Amazon.
SMC KQ2H04-M5A Brass Push-to-Connect Tube Fitting, Adapter, 4 mm Tube OD x M5x0.8 Male
http://www.amazon.com/gp/product/B004M8 ... UTF8&psc=1
$1.49 for two on Prime at the time I bought them.
I bought two packs just in case. (types with fingers crossed) They haven't failed yet.
Posted: Wed Mar 19, 2014 2:08 pm
by GeraldO
Yeah, I also ordered some of the Festo connectors from (http://www.kiowa.co.uk/products/QSM-M5- ... 16767/1008) as they were recommended elsewhere in the forums. I'm hoping that the replacement connectors last long enough for these new PTC fittings to arrive from the UK.
I wish I'd have checked amazon as well but oh well, shame on me for failing to google.
Fortunately the brass bits didn't fall out until AFTER I disassembled the bowden tube and was playing around with the fitting at my desk ;)
