Mach3 Documentation
Posted: Sat Apr 07, 2012 11:42 pm
For those of us using Mach3 to control our H-1s (one of the nice features) here is a link to the official
Mach3Mill Install and Config Guide. If you are new to Mach, you really need to work your way through this manual.
Re: Mach3 Documentation
Posted: Sat Apr 14, 2012 10:12 am
by lynx74br
Posted: Sat May 05, 2012 7:11 pm
by PartDaddy
H-1 General overview of getting from part to print:
1. Draw model in cad software, like autodesk 123D or Google Sketchup
2. Export STL file from CAD software.
3. Use Slic3r program to generate gcode from STL file. In slic3r, you'll find it easier to begin with settings found in our official docs section on the forum. There's also configuration settings for Mach.
4. Copy gcode file to the pc you're using to control the H-1
5. On the control PC (hooked to the H-1), start Mach3 CNC software and turn on power to H-1. Use the Mach Loader to start Mach with settings downloaded from our forum.
6. Zero x y and z by jogging the H-1 to the center top of the table (build platform) and clicking "zero" on screen of the digital read out (DRO).
7. In Mach, Open that Gcode file generated by Slic3r.
8. Click cycle start.
