Screw In Thermistors
Posted: Sun Mar 23, 2014 1:27 pm
I finally had it with thermistors pulling out. I guess I manhandle things too much.
Anyway, I picked up 4m .7 pitch set screws and matching tap & drill (#29)
1. Drill as deep a hole as possible without hitting the heat break on my E3D and tapped it.
2. Drill through the the center of the set screw. (Sorry, can't read the size of the bits I kept breaking...)
3. Put the PFTE tubes on the thermistor.
3. Pull the leads part way through the hole. You may have to twist to get them through.
4. Put a little Blue Magic QuickSteel around the place where the PFTE meets the glass bulb.
4. Pull the lead the rest of the way so that the bulb seats in the set screw.
I made up four of them just in case I need to change them out quickly.
This solution works with both physical sizes of thermistors - the tiny one and the larger glass bulb.
