Creaking u-joints
Posted: Mon Mar 24, 2014 8:04 am
I'm now calibrating my branny new MAX v2, but there's one significant issue: the joints creak. Any time I do a motion that isn't straight up or down I'll hear a "tick-tick-tick" as the delta arms swivel against the u-joints. The faster the joints are changing angle, the faster the ticking. Anything that loud is surely shaking the effector platform, which would at least mess with the smoothness of my results. I even used white lithium grease on all of the joints, to no effect.
When putting the arms on the u-joints, I found that some of the u-joint pins were a really tight fit into the arm holes, and needed significant pressure to get them to go in. I'm sure that this is where the creaking is occurring, and am thinking about disassembling the whole shebang and using a rat-tail file to gently enlarge the tightest holes.
In addition, although the u-joints spun smoothly on their axles when tested, after I put on the spring clips the u-joint-to-axle rotation got a lot stiffer. The weight of the arms could still pull them down, but not by much.
So, I have some questions for the assembled experts:
Dan
- Have any v2 owners had this trouble when assembling?
- Any opinions on whether lithium grease is good, bad, or indifferent for the various arm joints?
- Any opinions on just how smooth this all needs to be?
Dan
