				PLA vs ABS [poster/picture]
				Posted: Sat Mar 29, 2014 10:23 pm
				by brent
				Pretty neat graphic I found comparing PLA and ABS.
[img]
https://lh3.ggpht.com/-j55_LsIBjCE/UzdW ... aphics.jpg[/img]
				Re: PLA vs ABS [poster/picture]
				Posted: Sat Mar 29, 2014 11:02 pm
				by Tinyhead
				This makes me happy being a PLA printer... though i do admit i want to print others.
				Posted: Sun Mar 30, 2014 10:49 am
				I have been doing soak tests of the tenkara line spools and fishing reels printed in PLA. I printed 3 sets of parts. One is the control, i soaking in room temp water and the other soaking in 40°C water. These parts have been soaking for 6 weeks now and there is no observable effect on water soaking. Composting PLA requires significant heat AND moisture. For all practical purposes, it is not a problem to use in wet environments, like rivers and lakes!
One big difference to me is the properties of ABS and PLA. ***EDIT*** PLA - I meant ABS! ***EDIT*** is more flexible and for some applications this is desirable. It can also handle a bit more heat than PLA. PLA on the other hand is much stiffer but consequently more brittle.
I look at these materials as tools to solve design problems for my parts. The more tools (i.e. filaments) we have at our disposal, the better!
				Posted: Sun Mar 30, 2014 4:39 pm
				The content is drowned out by the grammatical errors.
If the author uses English as a second language, he could use a bit of work on tenses and the use of plurals.
If the author is a native English speaker, he should hide in his basement and practice writing until he doesn't sound like a total retard.
[Brought to you by Conan The Grammarian: To Serve and Correct]
				Posted: Sun Mar 30, 2014 6:26 pm
				by brent
				geneb wrote:The content is drowned out by the grammatical errors.
I didn't make it, just found the picture and felt it was useful for showing newbies differences between materials regardless of the errors.
				Posted: Sun Mar 30, 2014 7:08 pm
 Conan The Grammarian?
				Posted: Sun Mar 30, 2014 7:29 pm
				by McSlappy
				It's an interesting poster - though I argue the PLA is as stong as ABS. I'm not sure 'strength' is a great word to use anyway... They are both very strong, but ABS is more elastic than PLA under stress. If I wanted something to survive being dropped and treated roughly, I would use ABS.
It does clear up some misconceptions about PLA though, perhaps we should make a larger and Conan approved version?
				Posted: Sun Mar 30, 2014 7:53 pm
				by Pingel
				McSlappy wrote:It does clear up some misconceptions about PLA though, perhaps we should make a larger and Conan approved version?
My girlfriend is a graphic designer... only if she didn't currently hate me for choosing a printer over her this last week.
				Posted: Sun Mar 30, 2014 8:03 pm
				by McSlappy
				Tell her that you'll love her again if she does this....
Or I could do it since I'm a graphic designer too
 Eh no, I'm too busy this month :/
				Posted: Mon Mar 31, 2014 1:11 am
				by aehM_Key
				mhackney wrote:PLA is more flexible and for some applications this is desirable. It can also handle a bit more heat than PLA.
Meant probably ABS.
http://www.makeitfrom.com/compare-mater ... olylactide
				Posted: Mon Mar 31, 2014 8:27 am
				Yeas, meant ABS - thanks! I had the new PLAFlex on the mind when I wrote that!
