Snapped Limit Switch Lever Off
Posted: Wed Apr 16, 2014 3:21 pm
by heathenx
So...I was just explaining something to my co-worker when I accidentally bumped the limit switch with my finger and snapped the lever off. I understand that these levers are removable but what I don't understand is if by snapping it back into place does that change the calibration of the arm somehow. I kind of bent the lever and used needle nose pliers to bend it back to shape. What do you think?
Re: Snapped Limit Switch Lever Off
Posted: Wed Apr 16, 2014 3:53 pm
by JohnStack
Go for it! Worst case, new limit switch. They're readily available. A very common part.
Posted: Wed Apr 16, 2014 4:13 pm
by bvandiepenbos
you will need to recalibrate the Z height.
Posted: Wed Apr 16, 2014 5:31 pm
by dtgriscom
If you still get good positive snapping action from the lever, and it doesn't wobble (much) side to side, then you should be good in the long run. But, you will definitely need to recalibrate.
D
Posted: Thu Apr 17, 2014 11:18 am
by heathenx
Ah! I actually re-calibrate the z height quite often. I don't do it on every print but nearly every print. I did re-calibrate after I snapped the lever back in place but not because I thought I needed to, rather because it's habit. I printed a 4 hour print afterward and noticed nothing wrong with it. Printed as expected. Very satisfied with the result. I'll assume that I'm good to go.
Thanks everyone.
