Batwoman bracer
Posted: Fri Apr 18, 2014 10:15 am
My main reason for getting my Rostock was for costuming props, so here's another costuming prop I've been working on, which is the bracer for my Batwoman costume, the black one on the left obviously is the 3d printed one, the red one on the right is my original hand laid fiberglass one. The old was was a bit too bulky in the way it fit and it didn't fit well so I decided to print up new ones in 3d.
I'm very happy with how the 3d printed one came out, I ended up having to split the main body of it because it broke loose from the bed so I just cut off the spaghetti, measured, cut the model appropriately printed the rest and bonded them together. This was printed out of abs, also since regardless of how fine the print layers are I still would have to sand it to get it perfectly smooth to paint I just choose to print larger objects like this at a .4mm layer thickness for faster printing. I will say too that i'm loving the weight, or lack there of with the 3d printed parts, the abs one is significantly lighter than the old fiberglass one.
