Is this something I can pick up at Fry's? If so, can someone give me the specs of exactly what I'd need? To be clear, its the 2 LCD grey ribbon cables that connect to the main board.
Thanks
-David
You are a genius. Took a spare IDE cable, took it apart, and made two 10 pin cables. I now have the LCD working and am calibrating away...atoff wrote:Do you have a dremel?If you don't feel like waiting for SMC you could always take an old IDE cable and just cut it to size.
Sweet! Good job!whaleboy wrote:You are a genius. Took a spare IDE cable, took it apart, and made two 10 pin cables. I now have the LCD working and am calibrating away...atoff wrote:Do you have a dremel?If you don't feel like waiting for SMC you could always take an old IDE cable and just cut it to size.
Thanks
-David
