Thermistor identification question
Posted: Thu Apr 24, 2014 6:59 am
Hey gang, my hotend thermistor died in the middle of a job about 2 weeks ago and I finally got around to taking the thing apart and replacing it. I bought a 10-pack of new thermistors from Amazon (see below). Can someone please direct me to a discussion of how I identify whether I need to change the thermistor type code in the firmware? I've seen discussions of leaving it set to 1, setting it to 97, or installing some other custom thermistor table.
I don't think it's a perfect match for the SeeMeCNC stock thermistor, because when I turn the thing on, the LCD tells me that the hotend is significantly warmer than the bed (like +20c degrees warmer) which I don't think can be true. It used to be almost the same from a cold start.
This is what I bought:
http://www.amazon.com/RioRand-10-100Koh ... thermistor
RioRand(TM) Upgraded 10 pcs 100Kohm NTC Thermistors
Item:NTC Thermistor Model:B2-100-3950-1 R @ 25: K 100K-1% B25/50:K 3950-1% Element:Thermistor,type MJB2 Characteristics (1) Electrical characteristics A: Resistance value: R(25°C)=100K±1% B: B Value: B=3950±1% (calculated from resistance value at 25°C and 50C) C: Insulation resistance 50MΩ or over by DC500V megger (between glass and lead wire) (2) Thermal time constant (τ): τ≤10~17s (in still air) (3) Thermal dissipation constant (δ): δ=1.1~1.6mW/°C (in still air) (4) Operating temperature range:-50~+260°C
