How do you print with BRIDGE without (Angel Hair)
Posted: Thu Apr 24, 2014 1:30 pm
by ZionPhil
What is the secret to printing with the BRIDGE material without getting a lot of stringing. *NOTE* I am Air Struding
Retraction Settings for ABS (They are working perfect for ABS)
[img]http://i243.photobucket.com/albums/ff14/Maxxforce/Retraction_zps2c67841f.png[/img]
Example of printing with Bridge with ABS Retraction settings above
[img]http://i243.photobucket.com/albums/ff14/Maxxforce/String_zps5bd306da.jpg[/img]
Re: How do you print with BRIDGE without (Angel Hair)
Posted: Thu Apr 24, 2014 5:54 pm
Try backing off the temp a bit.
Posted: Thu Apr 24, 2014 6:32 pm
Agreed, the lower the temperature the less the strings, I'm currently printing it at 230, and if the stuff was actually in spec diameter wise I could probably print it at 210.
Posted: Thu Apr 24, 2014 9:11 pm
by ZionPhil
Have either of guys printed with the Taulman Bridge Filament yet?
Posted: Thu Apr 24, 2014 9:55 pm
Yes, I've been printing with it a lot recently, my comment applies directly to printing with it.
Posted: Fri Apr 25, 2014 11:57 am
by Jassper
Increase the speed of your retraction as well.
Mine is at 60, that helps create a suction on the nozzle when it retracts.
Posted: Fri Apr 25, 2014 5:16 pm
by ZionPhil
Thanks guys. I will try dropping 2 degrees and up my retraction speed from 35mm/sec to 60mm/sec
