Solvent For Welding/Smoothing PLA Like Acetone With ABS.
Posted: Fri Apr 25, 2014 3:48 pm
I've searched high and low to find what we can use to solvent weld and smooth PLA, but all Google has shown me are these crazy carcinogenic chemicals that are seriously hazardous to your health...
Until now that is...
Many people might even have this in their basement if they do a few plumbing fixes here and there, it's called Schwartz VC-100 and it's readily available at many hardware stores. It's slightly stronger smelling than acetone, I'd recommend a respirator if you're going to use it a lot, I even use one as a precaution with acetone.
Here is a link for Home Hardware:
http://www.homehardware.ca/en/rec/index ... 4105?Num=1
It works just like acetone on ABS, but it leaves a matte finish instead of a gloss. In the photo, the part on the left has been treated with VC-100 and the two scraps on the right have be fused together. If you get too excited you end up with a bit of a precipitate (white stuff on the left part). That's all I know from 10 mins of experimenting.
Don't forget to read the MSDS before you play with it!
Happy printing and sticking everyone!!
