anybody connected any zprobe to rostock
slashthedragon
Post by slashthedragon »
I've looked and can't find a working method. I have had some success getting a new zero location but not by using the information provided.
For one thing Repetier configuration.h 0.91 has it on pin 63. My RAMBo uses pin 10 for the z_min. It ain't never gonna work that way unless there is something I am missing.
Does anyone have the proper code to read and store the zprobe values?
BTW: I cannot search the forums for "z-probe" so I am using the spelling "zprobe."
PS had to edit configure.h #define MIN_HARDWARE_ENDSTOP_Z true
JohnStack
Re: anybody connected any zprobe to rostock
Post by JohnStack »
http://dropc.am/p/KhiI1a
slashthedragon
JohnStack wrote:Have you seen this?
http://reprap.org/wiki/Kossel#Automatic ... ling_probe
I had not seen that. It looks like the pin 10 which I have been working with is for the z tower not the z position. Thanks.
Back from taking a look-see. There was some information I can use.
What I learned:
It looks like they also use the Z-min input (I think it is a RAMP board). This is how I had approached the problem.
They do distinguish better the XYZ towers and XYZ spatial.
One diagram shows the x-min, y-min and z-min all being wired.
The configuration.h file was not the repetier version but it was a close cousin.
Back again. Success I have it sensing the zprobe. I am using pin 10 on the RAMBO. I put my x and y values for my probing points at zero to test without crashing. I am using repetier zprobe url for my reference.
Last edited by slashthedragon on Sun Apr 27, 2014 9:41 am, edited 2 times in total.
Thanks for that John, I also am building a mini kossel that info is invaluable.
