x axis direction
Posted: Sat Apr 26, 2014 7:12 pm
I had to change the stop switch on the x axis and when I fired the machine up again the x axis will only go down when I give it the go home command. I have changed the x axis invert direction entry from false(the original setup) to true and it still goes down with either option. I had to change the switch because I tried to bend the lever on the switch as I had run out of adjustment doing the x axis calibration in my initial setup.
