Print speed after infill extremly slow
Posted: Tue May 06, 2014 4:59 pm
by Elysio
Hi
Just a tiny question.
Why is the print speed after the infill reduced ?
I cant find any settings to avoid this b..... situation.
Always after teh infill the printing of he perimeters get slower than other regions ?
I set the whole speed for every parameter to 35 mm /s, but its slower!
Slicer is Slic3r with repetier 0.95f
I hope you have an answer.
Bye
Re: Print speed after infill extremly slow
Posted: Wed May 07, 2014 9:02 am
Because printing the perimeters more slowly results in a better finish.
Posted: Wed May 07, 2014 2:11 pm
by Elysio
Hi G.
Hmm ja, thats what it does, but why, I set all speed values to a constant value of 35mm /sec. So there can not be the possiblity that the perimeters can be printed slower.
Is there any value in the setting which overrides the Speed settings ?
Posted: Thu May 08, 2014 4:40 pm
Elysio wrote:Hi G.
It's hard to tell from your description, but I would guess from what you are probably seeing is the result of the minimum layer time in the cooling tab.
Posted: Fri May 09, 2014 2:56 pm
by Elysio
Thats exactely the right answer, thank you so much !
