Retraction causes massive jerk
Posted: Tue May 06, 2014 5:06 pm
by Elysio
Hi .
The retraction causes massive jerk over the whole chassis. ?
What can I do against it ?
Tnak you in advance, Bye.
Re: Retraction causes massive jerk
Posted: Wed May 07, 2014 9:01 am
What's your retraction length and speed?
Posted: Wed May 07, 2014 3:54 pm
by Elysio
Hi G.
Lenght 5.4mm
Speed 100mm
Set lenght now to 2 mm, seems to be better, Thank you for your pointing help.
Posted: Wed May 07, 2014 5:08 pm
Elysio wrote:Hi G.
Lenght 5.4mm
Speed 100mm
Also, your speed should be about a third of what you have or in that area.
Posted: Wed May 07, 2014 7:29 pm
by whaleboy
Eaglezsoar wrote:Elysio wrote:Hi G.
Lenght 5.4mm
Speed 100mm
What are the ideal PLA settings for this? My retractions are pretty rough too (although they don't shake the whole machine). Mine are set to the same, which was the default... 5.4 and 100
Thanks
-David
Posted: Wed May 07, 2014 10:55 pm
They should be the same for PLA and ABS. A retraction of around 2 with a speed of 25 to 35.
These are only recommended settings, it does not mean that you cannot experiment on your own and see what works best for you.
Posted: Thu May 08, 2014 1:11 pm
by whaleboy
Eaglezsoar wrote:They should be the same for PLA and ABS. A retraction of around 2 with a speed of 25 to 35.
I'll give those settings a try, my much higher settings might explain why my thin supports are fading out when doing quick extrude-retract-quick support-retract-quick extrude sequences.
It looks like my original settings (5.4/100) are included in the Seeme default settings download. If those are too high in general they should be changed as all newbies like myself will tend to be using that
Thanks
-David
Posted: Thu May 08, 2014 1:21 pm
by lordbinky
The settings may be right for how the RAMBO performs retractions, so make sure that's turned off ( I don't know what it's default is off the top of my head), if you are using a slicer's retraction method. Having both on will make for some unpredictable results.
Posted: Thu May 08, 2014 9:22 pm
by whaleboy
lordbinky wrote:The settings may be right for how the RAMBO performs retractions, so make sure that's turned off ( I don't know what it's default is off the top of my head), if you are using a slicer's retraction method. Having both on will make for some unpredictable results.
I have no idea, but I'm using Cura straight to SD.
What do I need to make sure is turned off?
Thanks
-David
Posted: Tue May 13, 2014 11:54 am
by lordbinky
Mine would show it in the eeprom if it was enabled. I forgot they removed it though in repetier .90,
sorry.
