Smoothieboard mount v2
Posted: Fri May 16, 2014 9:08 am
I updated my Smoothieboard mount to add cable holders for the steppers, thermistors and endstop wiring. It also moves the mounting holes to ears - I was getting tired off having to remove the Smoothieboard in order to make adjustments to the mount location!
[img]http://thingiverse-production.s3.amazon ... atured.jpg[/img]
Although intended for a Mini Kossel this can be used with any printer. You can use the mount holes (on the ears) to attache the board in the base of your Rostock or other printer first and then attach your board to the pillars. Another good reason for adding the ears!
cheers,
cheers,
