Home Towers (delta orion)
Posted: Fri May 16, 2014 1:14 pm
by Ilja
Hi, hope you can help me. When I home towers in the printer settings my extruder instead of going up goes all the way down until hitting the heat bed. then I have to switch the power to stop it from breaking. It was working fine before. Any advice how to fix it? Thanks.
Re: Home Towers (delta orion)
Posted: Fri May 16, 2014 1:31 pm
Ilja wrote: It was working fine before.
Before what?
Most likely you need to invert the stepper directions in the firmware, or you can rewire the steppers, but I'm assuming you changed something before this started happening?
Posted: Fri May 16, 2014 1:42 pm
by Ilja
well it was printing fine after I set the printer following the instructions in the manual when it arrived. then for a while I didn't use the printer, so I decided to calibrate Z height before using it again. While I was doing it I realised that I do not really remember if the way I am doing it is the right way. So, instead of working it out I have decided to refer to Orion User Manual which suggests first to home towers. When I tried to home them it led to the nozel at first fast and then slower going down and then continuously hitting the surface of the bed until I swithced it of.
Posted: Fri May 16, 2014 3:34 pm
by Ilja
Ehm, how to invert the stepper directions? :)
Posted: Fri May 16, 2014 4:59 pm
by Ilja
My firmware EEPROM settings show that Z max length is: -93.193. Could that be the reason why it is not homing properly? If it is, how to fix it?
Posted: Fri May 16, 2014 5:05 pm
by Ilja
That is what it shows.
Posted: Fri May 16, 2014 5:27 pm
Could well be, it's supposed to be positive
Posted: Sat May 17, 2014 6:27 am
by Ilja
Thank you for the answers and help. I am though a complete beginner in 3d printing. So I do not know how to fix it :) Any advice of what I should do and how?
Once again thank you!
Posted: Sat May 17, 2014 11:58 am
Ilja wrote:Thank you for the answers and help. I am though a complete beginner in 3d printing. So I do not know how to fix it :) Any advice of what I should do and how?
Change the negative value to a positive number. My Orion is about 202 for a zheight.
Once you get a positive number in the EEPROM, then go to LCD - advanced settings - calibrate z height.
Home Towers - Z position and turn the knob until the nozzle drags on a piece of printer paper then set new Z=0.00
That should be all you need to do. I have no idea how you ended up with a large negative number in EEPROM.
Posted: Fri Jun 06, 2014 6:23 pm
by Ilja
Thank you very much for your help. It looks like everything is working perfectly! So happy now :)
Posted: Fri Jun 06, 2014 9:41 pm
Ilja wrote:Thank you very much for your help. It looks like everything is working perfectly! So happy now :)
Great! Happy Printing!
