Rostox Max ignores gcode commands
Posted: Tue May 20, 2014 6:17 am
by Mac The Knife
Re: Rostox Max ignores gcode commands
Posted: Tue May 20, 2014 11:53 am
Mac The Knife wrote:I finished my build last night, and loaded the firmware, drivers etc. At first start up, I discovered that I had the hot end thermistor plugged into the wrong spot on the RAMBo. Once that was corrected, I have full manual operation of the printer through my laptop, motors, hotend heat, and heated bed. I can zero the Z setting in Rambo. However, it ignores any gcode commands sent from repetier.
Did having the thermistor plugged into the wrong spot cause the firmware install to be bad?
Most likely you haven't realized that Repetier is case sensitive
G1 Z100 F5000 -- Does work
g1 z100 f5000 -- is ignored
You have to home the axis before any move.
Posted: Tue May 20, 2014 12:09 pm
by Mac The Knife
Posted: Tue May 20, 2014 1:01 pm
Mac The Knife wrote:Thanks. I'll give that a shot. I did try M119, and m119, with no luck,,,, should it be separated? M 119?
The M119 is the correct one.
Posted: Tue May 20, 2014 1:34 pm
by Mac The Knife
Posted: Tue May 20, 2014 6:06 pm
by Mac The Knife
