Source for Bearing Sleeves?
Posted: Wed May 21, 2014 2:27 pm
by Brian
Are the bearing sleeves for the Cheapskate Bearings an off-the-shelf component, or are they a custom made part? One of my bearing sleeves is defective. The inside diameter is 0.015 smaller than the others and it's not smooth, so I can't finish my Rostock Max V2 build until I get a replacement. I managed to force the defective sleeve on the bearing, but it stretched out and makes the bearing contact area on one side more than the other, so it is trying to twist the cheapskate to the point it won't move freely. I dare not do anything more because I don't want to damage anything.
If this is a common part, can someone give me the part number or correct dimensions I need to order one?
Thanks.
Re: Source for Bearing Sleeves?
Posted: Wed May 21, 2014 2:31 pm
Why not contact [email protected] and have them send you one?
If you need something faster and if the sleeve you are talking about part of the bearing, that bearing is one of the most common and should be stocked
at a hardware store. The number is on the side of the bearing.
Posted: Wed May 21, 2014 3:06 pm
by guanu
pretty sure he is talking about the delrin covers for the bearings, and they are made here at the shop... as eagle said, contact support and we'll take care of it..
Guanu
Posted: Wed May 21, 2014 4:45 pm
guanu wrote:pretty sure he is talking about the delrin covers for the bearings, and they are made here at the shop... as eagle said, contact support and we'll take care of it..
Guanu
Never even thought of the delrin covers. Thanks for covering.
Posted: Thu May 22, 2014 9:10 am
by Brian
Support says it's on the way to me. Thanks!
Posted: Thu May 22, 2014 11:07 am
Brian wrote:Support says it's on the way to me. Thanks!
They are there to help, another excellent job from the support side of Seemecnc!
Posted: Thu May 22, 2014 12:07 pm
by guanu
I will take all credit... because I have an ego like that =)
Guanu
Posted: Thu May 22, 2014 12:29 pm
guanu wrote:I will take all credit... because I have an ego like that =)
Guanu
