Rambo death, layer height and calibration
Posted: Sat May 24, 2014 9:06 am
Hello all,
I have had my Rostock for some time now and recently recalibrated it to try and improve the print quality. Following the recalibration, I set it going on an overnight job - after watching it put the base layers down.
When I took a look in the morning, the print had stopped midway and the printer was completely dead. The switched mode PSU did not power up - even after changing the fuse in the plug and disconnecting it from the Rambo. All three fuses on the Rambo had gone. I have since replaced the PSU with a slightly upgraded (40A 12V rail - http://tinyurl.com/MyNewRostockPSU) version and replaced the fuses. The Rambo is still completely dead and it appears that the power rails are shorted out somewhere - the PSU cuts out (indicated by the cooling fan stopping) when it is plugged into the Rambo.
Can anyone tell me:
(1) How the Rambo could have been damaged to this extent - when protected by the three fuses? Could this have occurred as a result of the end effector colliding with a print and stopping the motors moving - or - the hot bed drawing too much current? I have ordered a new Rambo, but don't want this to recur again if possible.
(2) If there are any circumstances where the layer thickness as calculated by Slicr could be too small - so that the hot end starts colliding withe the print? If so, how can this be cured? Is it a setting in Repetier or the Arduino sketch?
(3) If there are any recalibration steps that I have missed which could improve my print quality - so far I have:
(a) re-squared the towers
(b) adjusted the belt tensions
(c) reset the end stops screws and centre point in the Arduino sketch
(4) The effect of having the hot bed temperature slightly higher (60 degrees instead of 55 degrees) on a PLA print? Currently, my print seems to be stuck - through the blue tape - onto the borosilicate glass bed. Rather than risk breaking the glass, I'm going to wait until the replacement Rambo arrives and warm up the bed then...
Img - The problem with being UK based - a temporary fast blow fuse hack whilst waiting for little fuses from Mouser
Senake
Can anyone tell me:
Senake
