Errors at end of print
Posted: Sun May 25, 2014 6:08 pm
				Hello - I've been playing around with Kiss and have getting some good results but have this annoying bug in Repetier-Host.
At the end of the print the nozzle freezes at the finishing point and I get error codes similar to the below lines, over and over again. The arm's won't reset to a home position, nor will the heaters turn off. Can anybody share their postfix GCode perhaps? or do you think it could be something else?
I've looked at that line in the code, but it doesn't make sense as it's only 1/4 of the way through the file (print actually finishes).
I'm currently using:
Slicer and Cura behave themselves at the end of the print....just can't figure this one out...
Error: expected line 31777 got 31789
Resend: 31777I'm currently using:
G1 X70 Y0 F5000
G28
