Hello from Crystal Lake, IL
Posted: Mon May 26, 2014 5:43 pm
Hello everyone.
I am about 8 to 10 hours into the build of my Rostock Max v2. I own a Thing-o-matic (from back in the day), and although my TOM is till working good, it needs a size and hot end upgrade. I really want to try a delta printer and the MAX v2 has everything I want - comes in a kit, good build size, open source, and what looks like a great community.
On a different note, I also own a Shapeoko 2 and I am a beta tester for Inventables Easel. I really like what they are trying to accomplish. Always interested in Shapeoko ideas as well. Currently have a laser engraver, printed drag knife, and multiple spindles working.
OK, so actually the v2 build is going quite well, but although I lined up the two plates of the cheapskate, when I completed the assembly I had put the u-joint carrier on the wrong side so the carriage is reversed with the eye's looking up to the left versus up to the right. When I caught it I tried to remove the u-joint spring clips but they are difficult to get off the axle and I cracked one of the clips, so I am afraid to damage them more. I installed the carriage assembly as is and they seem to work well and align acceptably. The question is can I leave them like this, or will this cause trouble later on down the line especially with calibration?
So my options:
1. Install as is but mirrored
2. Take my chances and try and remove/reverse the assembly (any advise on the easiest way to get the clips off?)
3. Order new cheapskate assembly
Any advice?
Look forward to sharing with everyone.
Thanks,
Mike
So my options:
Any advice?
Thanks,
Mike
