Adapting to print PLGA
Posted: Thu May 29, 2014 1:51 pm
by bvm5207
I am working with my PI about buying a 3d printer, but he wants to be able to print poly(lactic-co-glycolic acid) (PLGA). It is not commercially available in a filament spool, but we can make it in the lab. Is it possible to adapt the Rostock MAX v2 3D Printer and it's nozzle to be able to print PLGA?
Thanks,
Brian
Re: Adapting to print PLGA
Posted: Thu May 29, 2014 2:24 pm
Based entirely on what the Wikipedia page says, if it's not too soft when solid and if you can extrude it into filament, probably...
My question is what are you using it for? If it's supposed to be food safe, then you really don't want to use any FDM printer, the little ridges hold bacteria.
Posted: Sat May 31, 2014 1:18 am
by bvm5207
PLGA has very similar viscosity and melting point to PLA so I expect it to be theoretically possible to be printed. My concern was being available to make it into a filament and making it available to the nozzle to run smoothly.
The plan is to use this printer for research of bioprinted scaffolds or implants for the body. Bacteria wouldn't be too much of a problem; if we are going to perform cell culture we could clean the object.
Thanks for the reply,
Brian
Posted: Sat May 31, 2014 1:52 am
by lordbinky
Sounds really neat. Keep in mind, depending on the scale you plan on printing you can get very fine layers ( 20-50 micron layers have been achieved). With FDM you typically squish the material coming out between the surface area of the nozzle and the previous layer (or bed) so you get a wider trace as your layer size decreases. This trace width varies between the bore hole size and the width of the nozzle surface. Using smaller bore hole nozzles does compensate for this some, but you may need to figure out special nozzle design depending on what you are trying to achieve if you desire fine X/Y detail and small layers when designing scaffolding, I imagine implant design is less likely to run into necessitating both feature types.
Posted: Tue Jun 03, 2014 11:21 pm
by bvm5207
Very interesting. We are also intriuged by the potential to print microdevices (either fluid or mechanical in nature) with biodegradable PLGA on the surface, so fine layers of 20-50um would be desirable.
I will keep the trace width and bore hole size in mind when contemplating fine details in all 3 axis.
Thanks for the tips.
Brian
Posted: Sat Jun 28, 2014 2:52 am
by Generic Default
I can make you custom nozzles if you need them. I print with a 0.25 nozzle at layers typically less than 100 microns. I've done a few 20 micron prints, but they take too long for big stuff. If you are microprinting you should get 400 step/rev steppers for higher resolution and upgrade to magnetic ball arms.
Posted: Mon Oct 24, 2016 1:56 pm
by erickramce
Hi everyone!
Have someone successfully printed with PLGA? Did you extrude the filament or where did you buy it?
I wish you can help me!
Regards
