plan for acetone chamber. electrical/shopping advice needed.
Posted: Thu May 29, 2014 4:32 pm
I've been daydreaming about this for a couple of days, and was hoping for some advice.
I did very limited research on acetone vapor chambers and they all seems like difficult, jury rigged, expensive contraptions that require significant practice to operate
Here's my idea, assumptions and resources I would rather buy locally:
Print a jar lid with: heating element, acetone tank, fan to quickly expel vapor. place intake tube to bottom of jar so you can clear the chamber quickly.
I plan on making the heating element by wrapping kanthal wire around stainless steel mesh, for no other reason than this is how my e-ciggarette works and I have the supplies on hand. Thoughts?
Also print a PLA "object holder" to keep stuff off the bottom of jar. handle on top so you don't touch soft object
Thoughts:
-Acetone is heavier than air - why did all (2) of the chambers I saw produce vapor at the bottom?
-the examples I saw involved a chilled surface where the acetone condensed. is this needed?
-Is there any reason NOT to make a vapor chamber out of PLA?
-I'm planning on adding a fan to clear the chamber. do you think a circulating fan would also help?
-How can i tell in the store that the fan won't melt?
-If it doesn't explode - do you se any reason why this wouldn't work?
-I have never heated more than an inch of kanthal - is there better config than a single coil? should i use thicker wire? can i just use more power, or will this just cause the end to burn up before the center even gets warm?
-Should I submerge the wire, or use capillary action to pull up a small amount of acetone to the element?
-If i add a cooled radiator or filter to the exhaust pipe, could I safely use this inside?
What I need - shopping advice please! preferably local.
-Large threaded jar and giant washer- slightly larger than your print area
-How do I design/model a threaded cap for this? is there a sketch up plug in?
-Acetone-proof fan. I have motors from a CD drive. maybe print it? this adds a lot more labor to the design process though
-I have a 14v analog power source that i built in junior high. I'll probably just make wire holes and twist it together by hand, but CAD electrical design advice would be appreciated. has anyone used paint on conductors? do they stick to PLA? It would be neat to build-in a battery case and button for heat/fans, but this seems like a lot of work for a prototype.
as I am writing this during my break, I better get back to work. I'll edit it later.
Thoughts:
