Weaving? Could it be done?
Posted: Fri May 30, 2014 2:37 am
by Demolishun
I started thinking about the layer to layer adhesion issues. It seems to me there is a significant lack of strength between layers. I have seen issues on enclosures where the part will break at some weak layer. So I thought why not weave the layers?
How would that work? Well lets say you use a square wave, triangle, or sine wave pattern on one layer in the x/y axis. Then follow that up with an out of phase pattern for the next layer also in the x/y axis. However, the next layer "dips" on the peak of the out of phase pattern causing a mechanical dip down into the previous layer. It could even be setup to extrude sightly more material on the dip. This would cause not only a layer to adhere in a parallel direction, but also in a perpendicular direction of the 2 layers. Kind of like mini rivets with epoxy on the sides.
The math might be somewhat complex and I would probably really only use it for straight line runs. Like on exposed surfaces like perimeters. The finer the layer pitch the stronger it would be as well.
Re: Weaving? Could it be done?
Posted: Wed Jun 18, 2014 7:17 am
by brent
Very interesting idea. It would have to be implemented into the slicing tool after the math is worked out. https://github.com/alexrj/Slic3r
Posted: Tue Jul 01, 2014 4:24 pm
by RegB
Demolishun wrote:I started thinking about the layer to layer adhesion issues. It seems to me there is a significant lack of strength between layers. I have seen issues on enclosures where the part will break at some weak layer. So I thought why not weave the layers?
I'm not FULLY up to speed with Slic3r yet, but I seem to remember that there is a least ONE slicing program that offers an in-fill that is essentially a "weave".
Maybe not slic3r... I don't remember.
Posted: Tue Jul 01, 2014 5:16 pm
by enggmaug
I don't get it...
My mind cannot imagine how is it possible to weave layers, all math apart.
Actually, even with a thread and a needle, I can't imagine a 3D weave.
Posted: Tue Jul 01, 2014 5:20 pm
by enggmaug
However, my poor english led me to believe in the begining that you intended to do a wave.
Fluctuating in height on a sine pattern would bring more bonding surface between layers, and would make the parts stronger to shearing.
Posted: Thu Jul 03, 2014 6:31 am
by RegB
Isn't the "real" problem delamination ?
If so then I think it would be better to approach it as a "failure to properly melt into the previous layer" than as a weakness of the printing pattern.
From what little I know delamination is caused by not getting back to an area with the next layer until the previous layer has already cooled too much.
I can think of any number of potential solutions to this; Speed & area per layer being the most obvious ones, but design of the part being printed is the most likely source of the problem.
Posted: Mon Jul 07, 2014 9:50 pm
by snoman002
"Weaving" requires you get underneath a previously printed layer, thus it wouldn't be possible.
