Y tower will only go down
Posted: Sun Jun 01, 2014 12:49 pm
I just finished building my Rostock Max V2 and when I reached the point in the assembly guide where it asks you to "Home" the printer. When that starts the x & z axis move up to the stops, and the y axis moves down. I checked the end stop switches and they are working (according to Repetier-Host all are :L to start and will switch to :H when pressed) I then switched in the configuration file "INVERT_Y_DIR" from "false" to "true" and when I attempted to home again the y tower sat there and ground a bit without moving.
At the suggest of another thread I found on here I switched the plug on the RAMBo for x and y motors. when I switched these both the x and y motors moved down and the z moved up (I had inverted the Y in configuration.h so I assume that is what happened). I then put the motors back in their respective locations and switched the first 2 leads on the y stepper motor, same deal.
I am not sure what would cause the Y motor to only go down, if it is something about how I assembled it, or if the motor is broken but nothing I have found on here has worked
The firmware I am using is 0.91
